Results 1 to 2 of 2
Thread: Partner 1 rigid tapping issues
    Nov 2007
    Trying to rigid tap with a Cent 5 Partner 1. When the tap backs out, it usually pulls the part up and out of the vice a little. Any ideas? How does this machine run the tap cycle? What is the feedback to the controller? In the parameters it has "spindle encoder PPU" set to zero. Is there really no spindle encoder? Thanks!
    Oct 2006
    Are you certain that your machine has the rigid tap option? If the spindle encoder PPU is set to 0, that usually means that you do not have the rigid tap feature. You will have to use soft tap (G84) with a compression tap holder. If you would like to know if the machine has the rigid tap option please call Milltronics @ 952.442.1401.
  1. What exactly is Rigid tapping? Why people always ask does it do rigid tapping?
    By cjchands in forum General Metalwork Discussion
    Last Post: 12-19-2008, 09:19 AM
  2. Tapping head or rigid tapping
    By Gregory_C in forum Syil Products
    Last Post: 10-18-2008, 01:49 AM
  3. Partner VM17 issues
    By br1 in forum Milltronics
    Last Post: 11-14-2007, 09:57 AM
  4. rigid tapping issues
    By stebanski in forum Haas Mills
    Last Post: 06-14-2007, 06:56 PM
  5. Rigid tapping or tapping head
    By wildcat in forum Industrial Hobbies (Support forum)
    Last Post: 09-24-2006, 01:08 PM
