| Milltronics Discuss Milltronics Machines |
Hi, Been going through a Partner 1 I bought for my university. Two remianing issues: 1) I plugged the coolant pump and hit the flood switch, nothing happened. I expected the motor to spin up. There's no coolant in it, but I don't see a float switch in there anywhere. I tried the same using M08 and M09. 2) Yesterday the monitor started clicking like it was briefly losing power or something. Anybody had this issue. Thanks! |
| In many cases the flood pump will not turn on without the spindle being on. Please turn on the spindle and then try and turn the flood pump on. If you are still having the issue, please check the fuses inside the electrical cabinet. It sounds like the CRT may be failing. You can test this by connecting an external monitor. There is a CRT cable coming from the machine that plugs into the existing monitor, remove this cable from the existing monitor and reinstall to the external monitor. |
| Yep, spindle has to be on. Figured it out this afternoon when looking through the schematic, the pump relay can't energize if the spindle isn't on. I'll prepare for a CRT failure. One other issue is that the table kinda jumps at one point in it's travel. I hit the e-stop near that point and took off the servo cover to move the table through that point by hand. It moves smoothly so I don't think it's a mechanical issue. It only occurs at one point on the x-axis travel so I would not have thought that this would be a an encoder issue...assuming they are rotary encoders and a problem would cyclical. The table isn't anywhere near it's limits so I wouldn't think it would be a limit switch either. Any thoughts? Thanks. |
| 325 Coolant Pump | TurtleRacing | Tree | 4 | 04-02-2012 01:51 PM |
| Coolant Pump | bobs_charger | Tormach PCNC | 7 | 04-16-2009 05:19 PM |
| Need Help!- coolant pump | JACKSMACHINE | Fadal | 0 | 05-22-2008 03:13 PM |
| Coolant Pump | Smackre | Mechanical Calculations/Engineering Design | 7 | 06-29-2007 01:16 PM |
| coolant pump ??? | Loadedagain | Industrial Hobbies (Support forum) | 9 | 01-03-2007 12:54 AM |
