Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 03-24-2009, 01:50 PM
garnetram is on a distinguished road
VM machines with Centurion 6 and 7 controls and arcs
We have VM machining centers with both Centurion 6 and 7 controls. When we generate code from our CAM system we sometimes end up with very large arcs in the programs. These arcs DO NOT show in our cam simulation. Sometimes it can be traced to G2's being swapped out for G3's. And then sometimes it will only happen when we use a D offset on the control. So it has been hard to pin down, one time it appears to be the cam system and sometimes it appears to be the control. Has anyone ever expierienced this?
We seem to think that the out put from both the control and the cam system need to be in "synch" with each other. We use the same cam system with other controls with absolutly no similar issues.
Thanks!
Old 03-24-2009, 08:05 PM
Mortek is on a distinguished road
When using CAM systems you need to turn off the Trig help in the control. That is why you are getting erratic results.
Are slant bed machines superior to flat bed machines? Quickers General Metal Working Machines 15 03-28-2009 12:41 PM
PC Controls vs. Industrial Controls Billiam General CNC (Mill and Lathe) Control Software (NC) 0 03-16-2009 08:54 AM
Arcs Anxious Post Processors 11 09-17-2008 10:41 PM
Centurion 5 vs. Centurion 6 and validation codes Turbo VW Milltronics 2 02-11-2007 02:35 PM
TC,1 On newer controls what about the older machines.. chipsahoy Fadal 2 04-07-2006 06:59 AM
