| Milltronics Discuss Milltronics Machines |
I have a 1993 RW12 with centurion 7 control w/rigid tapping. I never did any threading on this machine and was wonderering if anyone can explain it. I tried to conversationally put a tap cycle in from the "thred" soft key. It did not work correctly. Any help would be greatly appreciated! |
| If you have the rigid tap option push program/conversational/new then enter a program number then enter The first screen that pops up is for program name , notes etc then push f1 to store , the next screen that pops up allows you to pick the operation , push the button for drill option The f keys will change , so you need to push the key labled start , the page will then pop up with the drill cycle highlighted , you then push the toggle button until the cycle you want pops up , tap cycle in this case , then push the down arrow to highlight the field right below that and push the toggle key until the operation you want pops up , in this case hard right At this point you need to push the down arrow key to highlight the features in red and enter the appropriate values , they are all pretty simple , # of threads ,spindle rpm, clearance as a positive value , and depth ,which needs to be a negative value. If your zeroed on the top of the work ( -.75 for 3/4" depth below the top of the work) . The other value on this page is pause in seconds at the bottom of the hole before reversing Then you need to push the store button which brings you back to the drill menu page , now press the position button at the bottom and a page will pop up which allows you to enter the XY coordinates of the holes to be tapped and a z value if different from the depth value plugged in on the previous page , once you have entered the coordinate hit store to return to the drill menu page . You can keep position to add coordinates for additional holes. When you have everything entered that relates to the hole or holes you want to tap you just need to push the end key (f3 ithink) and it will bring you to the last page that says something like disable drill cycle and push the store button again. Then just hit the exit button and it will save the program you have just written and your ready to go buy calling the program up from the menu and running it . I would reccomend you generate a sample file to tap at one position and then run it by cutting air somewhere above your part a few times so you can become familiar with whats going to happen . Then maybe practice on a scrap of aluminum . I would also save the program you wrote to a disk and open it on your computer so you can see just how simple the program is , once you figure out just how simple it is you will probably just write them manualy unless there really complex. here is a sample of the rigid tap file written by the cent 7 controller This file is for a 1/4x20 hole tapped at x0.00 y0.00 to a z depth of .75" O0102 (TAP ZERO) (Conversational File Centurion VII CNC 7.7341p C.F.) G20 G90 N1 G0 G40 M3 S800 G88 F[1/20] P2 R.2 ?-.75 G99 N2 G0 X0.00Y0.00 N3 G80 G1 N4 M5 M9 G32 (END OF O0102) |
| from the rigid tap example above here are the three important lines with a brief description of whats going on , all my rambling may be a bit more than you were asking for but hopefully will be helpful M3 S800 (turns the spindle on at 800 rpm CW) G88 F[1/20] P2 R.2 ?-.75 G99 (F[1/20] = RPM/20 so the spindle plunges at the correct pitch) (P2 is a two second pause at the bottom of the hole) (R.2 is hieght to rtract above hole ) (?-.75 is the depth to tap to ) N2 G0 X0.00Y0.00 (cooordinate of hole to tap) N3 G80 G1 (end canned cycle) |
| thats correct 800 rpm /16 = F50 for the milltronics the g88 f eed rate for 16 tpi would be G88 f[1/16] ... , then you can change the spindle speed to what ever works best for your material/tap/coolant combination and the F[1/16] should adjust the feed rate for what ever spindle speed your running |
| When using the rigid tap (which is an option on some machines), you do not have to calculate the rpm of the spindle. All you need to specify is the TPU and the how fast you want the spindle to rotate. The control will calculate the proper feedrate for the pitch that you specified in the conversational page. |
| Newbie- milltronics rw12 | vmani | Mastercam | 1 | 11-24-2008 06:24 AM |
| Threading on a SKT 21 LM | JohnBV | Hyundai Kia machine | 0 | 06-10-2008 01:02 PM |
| Need Help!- Threading D2 | Billet Sean | General Metalwork Discussion | 6 | 05-02-2008 12:40 PM |
| G76 threading | Kai_DK | Fanuc | 13 | 01-28-2008 10:37 AM |
| CNC Threading | cncuser1 | Mini Lathe | 8 | 03-21-2006 07:43 PM |
