Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 02-24-2009, 10:23 AM
genius is on a distinguished road
Milltronic VM30XP Spindle ZF Gearbox Failure
Our ZF 2 speed gearbox has had a failure in the planetary gear section. A planetary gear shaft set screw came loose and the shaft fell and jammed on an oil port boss. The spindle motor over came the boss shearing off some metal, the gearbox would then make a ticking sound at different speeds. I removed the gearbox and shipped it to ZF in Vernon Hill, IL. The ZF rep says it will only be $600.00 to repair the problem, they feel this failure came about from a harsh vibration.
Has anyone experienced any gearbox trouble?
Best regards,
Glenn
fadal spindle failure goechsli Fadal 63 08-22-2008 09:46 AM
Need Help!- spindle rebuild failure 50cal. General Metalwork Discussion 0 08-07-2008 09:56 AM
1993 VF2 Magnetek Spindle Driver Failure gar Haas Mills 19 01-04-2008 01:40 PM
Spindle orient failure on Shizuoka B-3v with 6m kstocklin Fanuc 0 11-14-2007 03:51 PM
Spindle failure mechanicer DIY-CNC Router Table Machines 9 10-31-2005 05:11 PM
