Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 01-05-2009, 03:10 PM
KurtsKustom's Avatar
KurtsKustom is on a distinguished road
Procedure for changing Z belt
Yep, we broke it today trying to get the Z to home. The Z is still trying to home in the negative direction, then hits the lower limit switch. It happened during a handwheel move. It looks like it would go over the top of the shaft from what I can tell from my preliminary disassembly.
Thx!
Kurt@Kurt's Kustom Firearms
Home of the M9EvoM4
Old 01-07-2009, 11:53 AM
jpawelk is on a distinguished road
I sent you a PM regarding as to why the axis is moving the incorrect direction. What type of machine are you replacing the Z axis belt on?
Old 01-07-2009, 12:33 PM
Partner IV.
I have the bolts out of the bottom of the screw's bearing housing, and turning the timing pulley/gear drops the screw down and out of the top of the upper housing with the upper bearing. Top bearing is off the screw's shaft now. The screw will have to come down and out of the nut, I presume, then threaded back in/up/through the nut after the belt is on. It looks like the timing pulley has to come off or be moved? It is larger than the lower bearing, and my progress stops there.
Thx!
Home of the M9EvoM4
Old 01-22-2009, 05:18 AM
bborb is on a distinguished road
Don't take the ballscrew out of the ballnut, bad idea.
Old 01-22-2009, 01:37 PM
Yes, I decided against that. Rather, I'll pull the nut after unbolting it from the head, and pull it forward with the screw in it to mount the new belt.
Thx!
Home of the M9EvoM4
Old 01-26-2009, 08:59 AM
OK, here's the prodedure. I installed the belt from the bottom. Pull the bearing housing from the bottom of the head, unlock and remove spanner nut, and drop the bearings (there are 2, both taper cone rollers, facing each other). I'm going to replace these 2 lower bearings as long as I'm in there. Slip the belt over the bottom of the leadscrew, and work it up into position. Reassemble. That's it! I got replacement belts from KSC Direct for under $9/ea. These are exact replacements for what was installed.
Thx!
Home of the M9EvoM4
Changing the main drive belt on the spindle Michael82 General Metal Working Machines 1 01-06-2009 08:09 AM
Procedure for BMU 6TA SGARCIAM Fanuc 1 10-25-2008 12:38 PM
Changing the drive v-belt ken65 Bridgeport and Hardinge Mills 2 09-11-2006 10:36 AM
Changing Z-Axis Timing Belt on Boss 6 snakebit95 Bridgeport and Hardinge Mills 4 09-10-2006 12:44 PM
