Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 12-21-2008, 10:52 AM
truckwiz is on a distinguished road
Partner 1 tool change
I have a partner 1 that does not have a tool changer. I am thinking of building a rack at the edge of the table to do a tool change from. How would I get the spindle to stop in the same place all the time?
Brian
Old 12-21-2008, 01:42 PM
converterk is on a distinguished road
Below the pulley on the spindle is a round disc with a circular cutout in the position where you want the spindle to stop. There is an air cylinder with a bearing on the end that fits in the cutout. There is a proximity switch on the air cylinder that tells when the bearing is in the cutout. Program a plc that when you call for a spindle orient, A-the spindle turns at 20 rpm, B-the solenoid that supplys air to extend the bearing into the cutout is energized C-when the proximity switch is made the inverter stops turning the spindle. I retrofitted a Partner 1E with a Centroid control and this is how I did the spindle orient.
Old 12-21-2008, 05:14 PM
One of Many is on a distinguished road
What type of spindle nose does the partner 1 have?
Is there a VFD?
Encoder?
Pneumatic valving etc?
I don't know if the Partner 1 uses M19 (spindle orient). If the machine did not come with an ATC, the parts required to accomplish the orientation would not normally be installed and the macro for M19 not part of the software package.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 12-21-2008, 06:05 PM
Cat 40 tooling, there is a encoder in the spindle belt encloser . The belt is missing that drives the encoder ,but I traced the wiring back to com 1 at the cpu. This machine never had a tool changer on it.
Brian
Old 12-21-2008, 11:48 PM
What is the control version?
On a Centurion 5, the spindle encoder should go to a connector on the Lower half of the X axis acroloop board.
If this is a Centurion 4, there may be others here with similar controls.
Those were quite different from the Centurion 1, 5 and 6. Com1 on these DOS PC based controls is the serial port.
DC
Old 12-28-2008, 07:49 PM
bborb is on a distinguished road
What does M19 do when you command it?
Old 12-28-2008, 08:26 PM
Provided there is a macro assigned and hardware to support the M19( like VFD, Encoder feedback and air lock pin), it should orient the spindled and lock it. It may do Z to tool change then orient and lock.
If it is not assigned, an error should be issued or it may time out or lock up the control if assigned, but no hardware to complete its task.....
DC
partner 1 tool changer problem blowncoupe Milltronics 5 10-30-2008 08:24 AM
partner 5 tool retention? Brian FRF Milltronics 10 01-16-2008 06:47 PM
Partner 1 Tool Changer not rotating Quadin Milltronics 2 01-15-2008 08:23 AM
How to change Tool change position(About MAZATROL T1 control) liushuixingyun Mazak, Mitsubishi, Mazatrol 5 07-07-2007 02:58 PM
Partner I Tool Change Problems Outlaw6700 Milltronics 2 02-25-2007 10:33 PM
