Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 12-20-2008, 12:20 AM
Captain Midnigh is on a distinguished road
Kaput
I still need help with my Partner 4 with century 4 controller. Was working good. Next day just stoped. When I hit restart, I get nothing. All voltages OK. Fuses OK. Switches on controller OK. Screen blank. Replaced battery on board, nothing. Help.
Old 12-29-2008, 07:06 AM
ksimmons is on a distinguished road
Try disconnecting the machine monitor and hooking it to an external monitor to see what messages you're getting.
Old 12-31-2008, 04:26 PM
I don't know where I would ever find another monitor.
Old 01-02-2009, 11:28 AM
Zug Zug is offline
Zug is on a distinguished road
The monitor on the Partner MB 20 at work died so we bought a $70 flat panel off Ebay, fabbed up some mounts quick and saved about $1200. Still working great after a few years.
Old 01-02-2009, 10:59 PM
I wish the Centurion 4 didn't use a monochrome monitor, then I would replace it with a flat screen like you did. I'm going to pull the connector plugs and clean them. See if that helps.
Old 01-05-2009, 11:14 AM
trevj1 is on a distinguished road
The monitor on our Cent V was monochrome, but the outut to it was VGA color.
We stuck a Philips LCD screen on it and it works fine.
Try grabbing any old computer monitor and plugging it in. Should work. No further behind if it doesn't.
Cheers
Trev
Old 01-07-2009, 01:19 AM
Ben Colby is on a distinguished road
The Centurion V's have a standard pc-type video connector. The Centurion IV's do not.
If your Centurion IV is the same as mine? it has a flat rectangular connector not a
pin connector . The monitor is a Toshiba monochrome. The Brother CNC's of this era
used the exact same monitor. I'm not sure if there is a any kind of adapter that might
get you worked up to a external monitor.
I believe from your user profile, that you reside in Washington state. There is a company
in Lynden, Wa. that handles this kind of problem and stocks legacy CNC monitors.
CNC Repairs and Sales Inc.
cncrepair.com
408-331-1970
Good luck
Ben
Old 01-13-2009, 01:58 AM
I'm not really having a problem with the monitor. It's the machine that won't start. When I hit restart I get nothing.
Old 01-19-2009, 11:10 PM
Can I replace the controler with something else?
Old 01-20-2009, 08:16 AM
Kevin Taylor is on a distinguished road
Kaput
Check the overload protection on the powersupply and all the fuses including the service pannel I'v had the main fuses in the machine blow one on startup the reset relays in any contactor's in the machine may be triped do you have power in the machine time to get out the VOM and check out the power supply be carefull around the big capasators lott's of volt's seem's to always be the end of a voltmeter that is set on to low of setting outside influence like lightnen or the power co working in your aeria Good Luck Kevin
  #11   Ban this user!
Old 01-20-2009, 09:54 AM
Yup. How much money do you want to spend?
The solutions range from getting Milltronics to install a new one of theirs, getting a third party to install a controller, down to the cheapest option, which is getting dirty with a bunch of hacked together components and Mach3 on a PC or laptop as the control. Or EMC.
Varying levels of commitment, both in dollars and in time invested.
Probably better to spend a few hours tracking voltages and checking circuits up front.
Good luck!
Cheers
Trev
Help! Bridgeport axis kaput arobustus Bridgeport and Hardinge Mills 5 10-24-2008 07:35 PM
Sherline Speed Control kaput mikkojay General Electronics Discussion 2 05-04-2006 11:59 PM
