Page 2 of 2 FirstFirst 12
Results 13 to 16 of 16
Thread: milltronics parner 3 y output wire wher does it go
  1. #13
    Nov 2008
    iowa
    sorry
    i thought you were talking about the terminal block in the drive
    but you are talking about the terminals by the relays? i check the voltage there at 12 and 22 and its 24v and i also did the jump wire there like you said at 6 and 9 and there was no change and no voltage across them is the top right relay or the double bank of relays suppose to be on all the time and are the lights on the servo boards suppose to be on b/c there not on
  2. #14
    Oct 2006
    Having 24VDC between TB12 and TB22 is good. The spindle drive is not the problem here. The problem is that Xin1 is not getting a ground signal. What is the staus of CR1A? CR1A is a relay located in the electrical cabinet.
  3. #15
    Nov 2008
    iowa
    we are on the same page
    we have the book for it and i found cr1a and its the top right relay in the double bank of relays and its always on the green light is on
  4. #16
    Nov 2008
    iowa
    info
    i look up cr1a on the diagrams and found it lead to tb3 slot 21 it says excess error when the light is on right ?
    i took the 21 wire off and the light on the relay went out (what does the excess error mean)
    but it still wont home you ask about holding the reset on the panel that didnt do anything i push f1 and then cycle start and it flashes the 450 error it comes up and then clears itself it says i have to push esc in the message but i dont have to push in it just clears itself does that tell you anything about the problem
  1. Milltronics phones
    By jpawelk in forum Milltronics
    Last Post: 03-13-2008, 11:55 AM
  2. MILLTRONICS ML-15/40- Anybody own one?
    By gunsmither in forum Milltronics
    Last Post: 10-23-2007, 12:36 AM
  3. Buy new Milltronics or what else???
    By schrupphobel72 in forum Milltronics
    Last Post: 07-17-2007, 08:17 AM
  4. New Milltronics Owner
    By Teps71 in forum Milltronics
    Last Post: 04-21-2006, 03:55 PM
  5. Milltronics
    By AMCjeepCJ in forum Suggestions for the CNCzone.com site.
    Last Post: 12-21-2005, 01:48 PM
