| Milltronics Discuss Milltronics Machines |
| I'm no expert , but I can relate from personal events : if the monitor was burned out , you'd probably still get a flashing reset light (unless its burned out ) . The computer is not communicating with the control . On my cent 5 , there is a regulated power supply that feeds 120 vac into the control . This box is below the main computer box and has 2 outlets on top . you can pull out the plugs one at a time and just jumper them to an extension cord plugged into the wall and see if it powers up the computer . One of these cord powers up a cooling fan and the other goes to a power supply inside the main box . If this yields no results, then the next step would be the power supply inside the main computer box . You have to take off the cover ( 8 small screws ) to get to the power supply unit . Similar to a computer pow box , it converts 120 vac to 12vdc. and 5vdc. legend on that box will tell what terminals are supposed 12v. there are 2 flat plugs P8 & P9 that plug onto the circuit board . this is where to check for voltage . b carefull! |
| Cent5 is all I am familiar with . maybe someone else can join in . But I stand by my original generic advice that you have to determine if the computer is booting up or at least getting power . When you turn on the main power on a cent 5 , and look at the screen quickly , it says "no input signal " for just a few seconds , if the computer is not sending a signal . |
| The 5 volt power supply seemed to be operating wierd. I pulled it out and it tested fine. When re-installed, wierd again. There seems to be a 1/2 volt feedback from the terminal strip feeding back into the power supply. Where would this voltage come from? The total voltage on the terminal strip is .78 volts instead of 5 volts. What next? |
| Check your cycle start button. Mine went bad and it caused havok with my CRT and it caused programs to E-stop all over the place. Check your E stop button, the control may be coming up in e-stop. Check your control/keyboard for any stuck buttons. When you power up with the front control consule open, can you see your CRT tube getting power? I apply contact cleaner on the ribbon connector once or twice a year. I also have to clean the wire connectors on the back of the tube occassionally. I get alot of corrosion problems where I live on the southwest Washington coast. You don't say if you are getting power to the servos after pushing reset? |
| saleCNC laser engraving machine and CNC woodworking machine | zhangrui1588 | Laser Engraving & Cutting Machines | 3 | 05-08-2011 03:54 PM |
| sell CNC Woodworking Machine,CNC Advertising Machine | zhangrui1588 | Product Announcements & Manufacturer News | 0 | 05-30-2008 08:43 AM |
| Deep Groove Taig machine would it be a good starter machine | Fritzie15 | Taig Mills & Lathes | 0 | 09-20-2007 09:37 PM |
