Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 10-27-2008, 02:51 PM
*Registered User*
ozturbo is on a distinguished road
Milltronics Centurion 4 amp capacitor
Hello,
I am in the process of finishing my conversion from the centurion 4 over to EMC and have one question. I ripped out all of the wiring and now I can't figure out what power goes into the large capacitor for the driver boards. I did find that it needs more than 30 volts for the drivers to power on but not any exact figure. Can some one check theirs and see if it is 120 or 72. Thanks
Old 10-29-2008, 01:20 PM
*Registered User*
Contacted Servo Dynamics and the capacitor receives 100vdc but I still cant source where it was getting its power
Old 10-29-2008, 01:29 PM
Al_The_Man's Avatar
As a general rule, those drives have a 120/240 or 240/480 to ~70vac transformer followed by bridge and capacitor.
The transformer is high VA, so it is not small, by any means.
Old 10-29-2008, 01:36 PM
*Registered User*
I do have the 70vac transformer connected, but the power from the capacitor came from a separate source. The driver panel I left completely intact, SD gave me 100 VDC for the power source but I dont have anything above 24vdc that came from the original control. At least as far as I can tell.
Old 10-29-2008, 04:37 PM
*Registered User*
Also, I didn't mention the drives do power on and the Voltages LED lights. Bu I check voltage going to the individual controllers and it is 72v so it is well within the drives range before error.
Old 10-29-2008, 06:09 PM
Al_The_Man's Avatar
So what is the actual problem that you have??
Old 10-29-2008, 07:59 PM
*Registered User*
I'm not getting power to the motors.
Old 10-29-2008, 08:32 PM
Al_The_Man's Avatar
If you have the correct power to the drives, then are they enabled?
If so do you have a command voltage?
If these are ±10vdc command drives, what are you using from the EMC system for command?
Old 10-29-2008, 09:03 PM
*Registered User*
I am using a board from mesa electronics for the analog signals. I am not enabling the boards at the moment, I was trying to get everything wired up first. I suppose I will hook up the enables and go from there. Thanks for your help.
Old 10-29-2008, 10:19 PM
Al_The_Man's Avatar
I usually use a ±9vdc battery box to check the drives before hooking up to the CNC control.
Old 10-30-2008, 10:44 AM
*Registered User*
I got another response from Servo Dynamics today that said the 100vdc must be supplied from a source that is isolated from ground and has to be clean.
Old 10-30-2008, 10:57 AM
*Registered User*
How would I go about isolating the power from ground?
Problem with a Milltronics VKM3 Centurion 6 WrenK Milltronics 14 11-23-2010 09:33 AM
Milltronics Centurion 1 Software & Manual TZ250 General CNC (Mill and Lathe) Control Software (NC) 1 07-01-2010 11:44 AM
Gibbs Post needed for Milltronics w/ Centurion Vii ABCOTIM Post Processor Files 0 10-08-2008 10:13 AM
Milltronics Partner ? Centurion V Servo Questions sbalder Milltronics 8 02-07-2008 09:35 AM
Milltronics Centurion Six CUTRITE Milltronics 10 10-13-2006 01:48 PM
