Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 10-02-2008, 09:36 PM
inkydo69 is on a distinguished road
Milling with CAM on Milltonics
I have had some trouble with the milltronics!
Does anyone know why the machine don't like to cut right when i program with a cam system. It don't like it when cutter comp is on and starts cutting all kinds of whacked out lines instead of a circle.
Any help would be much appreciated !!!!
Old 10-03-2008, 07:03 AM
LYN BYRD is on a distinguished road
THAT HAPPENED TO ME AND I FOUND OUT THAT I NEEDED TO SET THE PARAMETER FOR 90 DEG CUTTER COMP TO "YES". I DON'T KNOW WHICH CONTROLLER YOU HAVE THOUGH. HOPE THIS HELPS.
Old 10-03-2008, 02:59 PM
Mortek is on a distinguished road
You must turn off trig help when using a cam system, or you will get just the results you mentioned. Call milltronics for the parameter to do this on your control.
Old 10-10-2008, 12:23 PM
jpawelk is on a distinguished road
Depending if you have a mill or a lathe, the trig help can be turned off by editing the special flags parameter. This is a MISC parameter. For a mill edit the value to a 2. For a lathe, edit the value to a 3.
PCB Milling itsme Hobby Discussion 76 08-27-2008 02:53 PM
Milling with bottom vs milling with side? REVCAM_Bob CNCzone Club House 13 06-30-2008 09:23 AM
3D milling with TNC-155 praest General Metal Working Machines 2 10-01-2007 02:01 AM
3D IH Milling wildcat Industrial Hobbies (Support forum) 30 03-09-2007 05:32 PM
New to milling Marlboro Benchtop Machines 3 08-23-2004 12:37 PM
