Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 09-04-2008, 07:15 PM
hongfei is on a distinguished road
Angry Drive reset!
Cent 6, control boots up but no Error450 and Machine does not reset,.
I had checked the 24VDC and the wires. were all right!
And the watchdog LED’s lit green.
Can anybody could help me?
Old 09-20-2008, 10:13 AM
mastercamguru's Avatar
mastercamguru is on a distinguished road
Power supply is first thing to check - ok you checked the 24v dc but did you check all 3 legs ov 3-phase to machine? Often control will come on if one phase has burned a fuse. I am assuming you checked all the breakers and fuses in the machine. It is uncommon to lose servos without an error code. If the servo controller board lights up and there is good power supply the servo itself is junk. Very unlikey. Try the breaker reset first. Then power up and after control boots hold in the power and reset buttons at same time. This should reset the servos. If you hear them click on the machine may still be locked. Usually you can move the z+ by holding reset button while moving z+ in handle. Only other thought is that you haven't cleared a residual alarm. (user alarm vs machime alarm)
Old 09-21-2008, 06:53 AM
bborb is on a distinguished road
You ask how to fix your machine but fail to tell us what machine it is. I've done that before, it's embarrassing. Couple ideas: Check air pressure. Reload parameters.
I've seen where the error screen comes on but goes away so quickly it's as if it never came on, although error still exists.
Old 09-26-2008, 04:09 PM
jpawelk is on a distinguished road
What is the status of X input 1?
Old 10-06-2008, 10:47 AM
the status of X input 0, now the machine had an other problem: the screen diplayed "Empty spindle and load tool changer. press esc when set up is complete." when I pressed UTIL-TLCHNG-CW or ccw. After pressed "esc" it diplayed "The control os assuming that the spindle is empty. if there is a tool in the spindle remove it, press esc to continue. Also it have no actived when I pressed "UTIL- TLCHNG-home"
I don't know the cause. how can I to resolve it?
Old 10-10-2008, 12:19 PM
What is the status of X input number 1? Is it a 0 or is a 1? Also what is the staus of relay K1? This relay should not be on unless the machine is in reset.
Newbie- Z-SHIFT RESET? mmussack G-Code Programing 0 05-07-2008 05:08 PM
Remove drive belt on 96 VF-1 w/ TSC/ reset spindle orient bob1112 Haas Mills 6 01-09-2008 07:24 PM
reset zero jrick Commercial CNC Wood Routers 7 01-13-2007 04:54 PM
VMC-966 (reset) )= novydcute General Metal Working Machines 0 10-18-2006 02:09 AM
MM2001 reset (or not...) Jalex CNC Wire Foam Cutter Machines 0 04-29-2006 11:20 AM
