Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 08-22-2008, 06:49 AM
kokai is on a distinguished road
vm 24 occured alarm of 450
The machining center is VM24. it had occured an alarm as 450: Emergency stop condition. Reset drives or press <ESC> to clear this message. I pushed the “reset” button the machine has no active and as same as previously. So I check the 24 volt power supply, the value is 24.3 volt, it like ok and the wires contact are all ok. I found the relay of “CR 29” is not work. How can I let it work? What’s the work condition?
Amp Alarm bbrreid General Electronics Discussion 4 02-29-2012 05:13 PM
NEED HEELP ALARM #414 Y AXIS SERVO ALARM? PICMAN Fanuc 6 04-29-2011 05:20 PM
ALARM shuttle drawbar alarm haas timmydabull Haas Mills 27 10-30-2009 08:27 PM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
401 and 420 alarm lockmachinist Fanuc 1 09-20-2007 09:24 PM
