| Milltronics Discuss Milltronics Machines |
I have a Cent IV controller on my lathe with an 8 station pragattie turret. Today I screwed up and had a boring bar that stuck through the end of the tool holder too far and when the turret went to index it jammed the boring bar against the side of the turret. But now it won't index. I checked all the fuses I could find and there are no blown fuses. When I give it an M06 command you can here something click in the cabinet and the turret hums but no movement. Any ideas on where to start? Joe |
| Ok, I took the end cap off and indexed the turret by hand. I tried an M20 and nothing happened. I tried and MDI tool change and again nothing. If I try a manual tool change and try indexing the turret manually from the back I can feel some resistance and some humming noise like it is trying to do something but nothing happens. What next? Joe |
| Are you sure you have all 3 phases it sounds like you lost one. double check for from phase to phase to phase on the top side of the relay you should have 220v across all 3. if you have it there then check at the motor when it is trying to turn you need all 3 phases. |
| OK - I checked the voltage at the motor and it is the same as at the main disconnect switch; 118v to ground on two of the legs and about 230-260v to ground on the wild leg with 234v between the two balanced legs and between 260-271v from either of those two to the wild leg. Please help. Thanks Joe Last edited by Joe Miranda; 06-25-2008 at 07:31 PM. |
| Joe cant help with the crash, but when I had my ML 20 upgraded with Pragati 100 turret we mounted a 3 HP AC motor drive that has 220 volts single phase input and outputs 220 volt balanced 3 phase to the turret. The CNC control tells the motor drive when to go and what direction to go. 2 years and no trouble. I jamed a boring bar like you and had an instant drive overload fault that stopped the turret before any damage could occur. The amps are programmable in the drive and the response time is in miliseconds. Got the drive from Automation Direct .com. I have converted all of my band saws and drill presses with 3 phase motors to this type of drive to run in my single phase shop. I hope your problem is simple electrical fuse or breaker tripped but if not Bob at Milltronics parts can have you up and running in a jiffy! Good Luck the Farmer |
| I have been told that when you index the turret manually and you notice a different feel as you rotate it that it is because it goes throug ha a clamp/unclamp sequence that uses a spring loaded plate to differentiate between the positions so I don't think that anything is bent. Besides that, it wasn't that kind of an accident. The turret only indexed probably about a degree before it encountered the obstruction. But I am not sure how long it was trying to complete the tool change before I hit e-stop. I did take the motor off and it does smell kind of burnt. Also, I did an ohms reading between the legs at the motor and one of the legs shows higher resistance (or whatever ohms measures) than the other tow. Does that mean the motor is bad? Joe |
That sounds like a pretty cool solution but I think that is way beyond my capabilities. I know where to hook the leads up to the machine and that is about it. What you did sounds ovewhelming to me. Bob at Milltronics is the go-to guy? Should I ask for him by name or is he the only one in that dept? Joe |
#10
| Bob works for Milltronics parts. You may contact him for any parts questions or orders. If you have any service questions and/or concerns please contact Milltronics service department @ 952.442.1401. |
#11
| OK. I pulled the motor and took it to a motor shop. They verified that the motor was burned up. They rewound it and replaced some coil in it. I put the turret back on and gave it a tool change command and still nothing. I checked the leads at the motor and I am not getting power. Before I pulled the motor I had power at the motor. What could have happened and where should I look next? Joe |
| Converting my Engine Lathe to an 8-Station Turret Lathe! | widgitmaster | General Metal Working Machines | 93 | 10-31-2011 03:27 AM |
| Turret lathe CNC retrofit? | MattiasCarlsson | General Metal Working Machines | 1 | 01-05-2009 05:15 AM |
| Turret for a cnc lathe | mtechserv | General Metal Working Machines | 4 | 02-17-2008 05:01 PM |
| turret trouble 4ne | markjb | Fanuc | 3 | 05-10-2007 08:19 AM |
| LMS Lathe Turret | CNCadmin | General Metal Working Machines | 1 | 11-28-2005 09:41 PM |
