Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 06-17-2008, 09:02 AM
jkinz56 is on a distinguished road
spindle wont turn
I purchased (2) used Partner 6's with the Centurion 5 controlers. These were running machines that were actually making parts when I bought them. I've now got them all set-up and ready to run in my shop, but when I run a progran the spindle wont turn. Even when I try running one of the previous owners old programs the still spindle doesn't turn.
Does anyone have any idea what's wrong?
Old 06-17-2008, 12:46 PM
JH-Q is on a distinguished road
Sorry, i thought it was a lathe, my mistake
Old 06-18-2008, 06:39 PM
bborb is on a distinguished road
I've seen some spindles that won't run unless the coolant is on.
Old 06-19-2008, 07:03 AM
hoidahl's Avatar
hoidahl is on a distinguished road
We have a milltronics and the operator came to get me because the machine wouldn't work anymore. He had the spindle overide turned all the way down to 0.
Old 06-19-2008, 10:45 AM
jpawelk is on a distinguished road
Try commanding a S500M3 in the MDI menu. Does the spindle turn on then? Does the control think that the spindle is on? In the information box, does it say the spindle is OFF, CW, or CCW? What is displayed on the spindle inverter when you command the spindle to rotate?
Old 06-23-2008, 10:48 AM
mholden is on a distinguished road
Try and hit the tool change reset button if the spindle works after that then you have a limit switch shorted to ground
Old 06-24-2008, 11:19 AM
msomerville is on a distinguished road
I am having that exact problem with my vm30. That is a short problem? My repair tech was going to chase it through some relay board in the back. Could it be any limit switch, or is there a specific one I should look for.
Old 06-24-2008, 11:34 AM
The limit switches go to terminal block 6 7 8 and 9
unhook the wires and see if any are shorted to ground terminal 6 to 7 is the X axis 7 to 8 is the Y axis and 8 to 9 is the Z Most likely the X or Y wires are shorted the switches should not be the problem.
Old 06-26-2008, 11:17 AM
You have obviously turned the spindle by hand. I have had the orient stuck and had to "unstuck " it.
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 05:51 PM
Problem- SX3 Spindle Motor Wont Turn ON ddexd Benchtop Machines 5 02-07-2008 06:30 AM
Boss 5 series 1 BP, spindle wont start signweld Bridgeport and Hardinge Mills 3 11-16-2006 06:21 PM
Ver 7.0 Eztrak 2 axis. Spindle wont turn MrMudd Bridgeport and Hardinge Mills 3 06-13-2006 01:18 PM
Motors wont turn moto21 Mach Software (ArtSoft software) 15 09-22-2005 10:13 AM
