Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 04-23-2008, 07:30 AM
Joe Miranda is on a distinguished road
Help getting started
I recently bought a milltronics lathe with a cent V controller. It has the capability of being programmed in g code or conversationally. I have stumbled my way through a couple of programs conversationally by looking at the one example I could find in the manual and then doing a lot of guessing. But I am far from happy with my progress. I am wondering if anyone here would be willing to help me out a bit. Say for example, give me a step by step if I included some simple part drawing. Any help would be much appreciated. By the way, I am fairly familiar with programming knee mills and I regularly use a TRAK lathe at my other job so I am not totally in the dark but I think a little help would go a long way here.
Thanks,
Joe
Old 04-24-2008, 09:57 AM
JL Fabrication is on a distinguished road
Joe,
Just to let you know I believe you asked some questions about the post processer for bob cad for you lathe and they only have one for the Cent. 6 Have you tried using this post processer? I talked to Milltronics yesterday and as far as a cent 5 vs cent 6 goes most all g-code are the same so for simple programs the post processer for the Cent 6 may work for you. I have not used Bobcad for programing a lathe only mill so I can't be a lot of help beyond this.
Jason
Old 04-24-2008, 11:30 AM
bobcad post
Jason,
Thanks for keeping me in mind and letting me know regarding the cent 6 post. I have not tried that but I will. I am a one man shop (well, my 16 year old son helps me when I get in a bind) and I only do this on the side - so time is not a commodity that I have a lot of. If I had time to play around with the control and the bobcad software I am sure everything would be fine and dandy but as it is I am always pressed to the limit to get some job or other out the door and I am always trying to pick people's brains so I can make faster progress. Thanks for your input. It means a lot to me.
Joe
How do YOU get started? mrcodewiz General Metalwork Discussion 1 04-21-2008 10:07 AM
Need some help getting started ranchak DIY-CNC Router Table Machines 8 09-17-2007 08:25 PM
Getting started with CNC Axisgr Open Source CNC Machine Designs 0 06-02-2006 08:55 AM
getting started on the Z craftech DIY-CNC Router Table Machines 5 01-09-2005 05:52 PM
Getting Started johnm99 DIY-CNC Router Table Machines 5 11-12-2004 03:59 PM
