Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 04-12-2008, 03:59 PM
Joe Miranda is on a distinguished road
powering down the control
I have a Centurion V control. I do not see a method for parking the machine or preparing it to power down the system prior to turning it off. Should I be doind something other than just turning the switch off?
Joe
Old 04-12-2008, 04:01 PM
Al_The_Man's Avatar
Often it does not matter, But given the choice, I would push the E-stop, turn off the controller, if it has its own switch, and then the main Disconnect.
Old 04-12-2008, 05:16 PM
chipsinpan is on a distinguished road
I used to get in the habit of homing my machine at the end of the day with the reasoning that it would be quicker to get it up and running the next day .
My sales rep /programmer guru who I really trust told me to stop this practice . He says to let it go thru the full home sequence each day .
Also , the correct procedure to shut down is to always E Stop first .
This powers down the drive boards . Then flip the big switch on the back of the control box to kill power to the fans ,vfd controller , cpu power supply .
If you think about it , this is exactly the reverse procedure of start up .
Old 04-12-2008, 08:48 PM
powering down
Thanks gentlemen. E stop first then power down. Got it.
Joe
15i control help for (AiCC) (hpcc) high precision contour control programming gibbsmaster Fanuc 2 12-28-2007 09:57 AM
Using Flashcut CNC Spindle rotate card control to control laser power pyroplotter FlashCut CNC 0 10-15-2007 09:46 PM
Fanuc OT-C Not Powering Up JerryH Fanuc 4 08-22-2007 06:34 AM
Input signal fails when powering up drivers. Witsenburg General Electronics Discussion 2 07-02-2007 03:02 PM
Transformer on ebay AU for powering CNC Greolt Australia, New Zealand Club house 0 06-19-2006 01:54 AM
