Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 04-07-2008, 11:34 AM
kokai is on a distinguished road
system halted!
the control system is centrion 7, when it run regular it could stop occasionally, like system halted! who could tell me what is the reason?
Old 04-11-2008, 07:57 AM
jpawelk is on a distinguished road
When the machine stops, does the control display a message?
Old 04-11-2008, 09:55 AM
sir:
no message displayed and no actived! Like a computer system halted! when I powered off then powered on, it could to resumed normal. I want know the reason and how to avoid the problem after?
Another question about Milltronics, I have some other problem about Milltronics, I had contacted Bill and other partment several times. but I had no replied from Milltronics. What's wrong about Milltronics corporation?
Old 04-11-2008, 11:40 AM
moldcore is on a distinguished road
Could it be a translation/communication problem? Your questions here are hard to understand, Milltronics corp. could be having the same problem helping you. Where did you get the machine from? Have you tried to contact your distributer. Most random shutdowns can be attributed to loose wire connections. How old is the machine? Has it seen rough service?
Old 04-11-2008, 04:18 PM
Originally Posted by kokai View Post
sir:
If you can please provide me with a machine serial number I can be of more assistance to you. When the machine stops, are any of the front panel keys responsive? Please feel free to email me at jpawelk@milltronics.net. Thank you.
Old 04-12-2008, 01:00 AM
Sir:
I had posted an email to you but the servers responses a message:
"This message is generated by COREMAIL email system."
"I'm sorry to have to inform you that the message returned"
"jpawelk@milltroncis.net DNS query error: milltroncis.net"
I had posted an email use other email address, were you received it?
Old 04-12-2008, 06:22 AM
pixburghenat is on a distinguished road
Sir:
Check your spelling of milltronics.
On your machine, have you checked the oil level in the auto oiler?
If oil is low, machine NO GO.
pix
Some of my best finds were in the trash....
Old 04-12-2008, 08:36 AM
wcopley's Avatar
wcopley is on a distinguished road
we have a VM30XP Cent7 control and had this happen It was being caused by a external keyboard. I found out by accident no one had a clue and it was brand new.
Bill
Old 04-12-2008, 09:07 PM
All conditions were alright what to run the machining center.
We have not installed external keybord before.
were there some problems about system or motherboard?
Old 04-13-2008, 07:11 AM
Okay, the machine is running?
Does the machine stop while it is cutting something?
Does the machine stop when you load a new program?
I had problem with the program filenames.
You can not use the letter 'O' for the first letter of a filename.
The control will crash.
I also avoid using the letter 'P' for the first letter of a filename.
The letters 'O' and 'P' are reserved for the conversational program names.
pix
  #11   Ban this user!
Old 04-13-2008, 10:47 AM
pix
Yes, the machine stopped while it was cutting workpiece!
then have no actived, nothing could run or active.
  #12   Ban this user!
Old 04-18-2008, 01:50 PM
crosbowkid is on a distinguished road
I am having an error message pop up of 449 drive fault, when this happens I can not do anything but power down to get rid of it. I can see in the main panel that the x-drive is the one faulting with a red light beside resolver fault. Can you tell me what could be causing the problem?
Old Ah-ha system RakmUp Stepper Motors and Drives 7 10-31-2008 05:49 PM
Not sure which system to buy? hd-fatboy Benchtop Machines 3 01-02-2008 10:29 PM
CAM System Down Home Fanuc 4 10-26-2007 06:40 PM
new 201 system rickwinters Gecko Drives 6 12-20-2004 10:10 AM
