Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 04-06-2008, 03:53 PM
panaceabea is on a distinguished road
RS232 FILE TRANSFER TIME?
All my other machines have USB ports and file transfer times range from seconds to at most a couple of minutes. I have an RW15 with Cent7 controller and for files larger than 1.4m it seems to only option is the rs232 port , some of my more complex 3d surface files are 5+m in size and transfer at 9600 baud for a 5m file is taking me aprox 1.5 hours. This is the only machine I have which limits me to rs232 comunication so I dont have any thing to gauge it to but is this a normal amount of time to transfer a file this size?
I have the baud rate , bits parity etc set correctly on both ends . The cent7 controller give the option of changing the transfer rate to 19200, which I did on both ends (controller and computer) but cant establish communication at this rate. Any help or thoughts greatly appreciated.
Milltronics will you be offering an upgrade which might add a USB port to the cent 7 controller at some point?
Old 04-07-2008, 08:30 AM
jpawelk is on a distinguished road
Milltronincs does not offer USB for the Centurion controllers. If you have a control with a single board computer, (All Cent 7 controls do) you can purchase a multi-card reader which allows the user to use a compact flash card, memory card, SD card, etc to transfer files. The option comes with a reader/writer that plugs into the USB port on your computer. If you have questions or would like to order the card reader, please contact Milltronics parts @ 952.442.1410. Thank you
Old 04-07-2008, 10:07 PM
single phase's Avatar
single phase is on a distinguished road
panaceabea, yes that is a normal amount of time for transferring a file of that size. I used to have to do it all the time before I added Ethernet to my VM-15.
Old 04-07-2008, 10:54 PM
anyway to add an ethernet/network card to the cent7 ?
Old 04-10-2008, 12:46 PM
mholden is on a distinguished road
Yes that is an option through Milltronics.
Need Help!- Mazatrol T Plus file transfer ict Mazak, Mitsubishi, Mazatrol 1 04-22-2008 10:28 PM
Free DNC RS232 software for serial file transfer bborb Machine Problems, Solutions , Wireless DNC, serial port 1 08-04-2007 06:28 PM
File Transfer roninB4 CNCzone Club House 3 08-27-2006 11:05 AM
file transfer axis overtravel Fadal 13 01-26-2006 09:55 PM
EIA file transfer grunemh Mazak, Mitsubishi, Mazatrol 0 12-02-2005 07:45 AM
