| Milltronics Discuss Milltronics Machines |
| What is the correct way to move my table to a location in reference to home relative ? If I program a rapid move at the end of a program to change parts , and do that as a position in relation to a g54 or g55 , I risk an overtravel if I dont put the vise in the same location every time . I know that if I write the location down as a g54 zero location ( param/coord/g54) I can do a g53 to go back there later . Today after running into an overtravel , I just used jog to physically move the table where I wanted it to rapid to for a part change , then toggled to work3/G56 which I was not using , then set an X/Y zero . Then went back to params/coord/G56 and wrote down the X/Y values . Edit program and put these values in the last event . Now I can be assured that this program will never run into overtravel , although it may not necessarily go to the exact location I want to change parts at . I am sure there is a better way to go about this , so tell me how ! I have tons of programs that I (incorrectly) put in rapid moves as G54/G55 positions instead of home /rel. |
| Hello, Please, correct me if I'm wrong. But couldn't you change the G54/G55's to G53 and reference from the home position this way? I'm assuming the moves are at the end of your programs and at the tool change? pix
__________________ Some of my best finds were in the trash.... |
| If I am reading you correctly, you want a point to go to at the end of the process to get the spindle out of the way to change parts etc. What I do on my machine is set up a virtual fixture (I use G59) and when I do a tool change or part change, do a G59 G0 X0 Y0. I do this, as I do not know until setup exactly where I will want this specific location. However, the post processor in my cam doesn't care and just puts the appropriate code in place. Hope this helps and I have read you post correctly.
__________________ Art AKA Country Bubba (Older Than Dirt) |
| Bubba , as I read it you are saying that G59 ,( which would be work 6 ) is used as a virtual fixture , meaning a theoretical one . Then you physically move to the location you want to change parts and call this XY zero , program a position as work coord 6 /X 0 / Y 0 / G00. I guess this is doing the same thing I explained , and as long as I never use G59 for an actual work location , I could just leave it set , and it would get me close . I could fine tune it as needed. I just thought there would be a more proper way to do this . Where is JPAWELK when I need him ? |
| Yep, you got it! This way, I don't care where G59 X0 Y0 is when I cam it, but I determine this when I do my setup. I rarely use more than a couple of fixtures so I settled on the "standard" of using G59 as my tool change/ parking position. Also, this requires NO manual changes to my g code! I let my cam do its thing and then select my parking/ tool change position based on the setup that I have.
| Hi: For our VMC I modified the Post to strip out the X0 on a G28.I used to get annoyed when the table moved to X0. e.g. G28 Z0 ;retract Z G28 Y0 ;push table fwd. This pushes the table towards me (most of the time the vise is centered on the table) Works for me. regards |
| DIY-Rapid Prototyping machine | slave1driver | DIY-CNC Router Table Machines | 29 | 11-15-2011 04:50 AM |
| DIY rapid prototype machine | cacuff | CNCzone Club House | 3 | 08-28-2011 07:43 AM |
| Fanuc 0M.. how do you zero relative? | OC_ | Fanuc | 5 | 02-23-2007 10:45 PM |
| Subtractive Rapid Prototyping Machine | rweatherly | DIY-CNC Router Table Machines | 2 | 12-13-2006 08:18 AM |
