Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 03-28-2008, 07:44 AM
abrege is on a distinguished road
Partner VM16 series A stuck in dos
Here's what happened. I sent a file from my computer that was too large for the memory, when it filled the memory, the machine shut down, and the screen went to dos, and said that you need to power down and back up to restart the controller. Did this, and it took forever to boot up. When it did come up, it went directly into dos. Can I delete the program file while in dos to free up memory? Will the software start when I power down/up the machine after doing this? HELP!!!!!!!!!!!!!!! New to milltronics.
Old 03-28-2008, 03:00 PM
single phase's Avatar
single phase is on a distinguished road
if you delete the g-code file from the dos prompt that should not hurt anything.
use the dir command to see the directories,
use the cd command to change directory and
use the del command to delete the file.
Old 03-28-2008, 09:54 PM
kokai is on a distinguished road
generally the directory like below:
usually the directory like below if you install a hard disk:
A: \ROM
B:\RAM\
C:\PARTS\ (HARD DRIVE)
D:\ (FLOPPY)
E:\ (GRAPHICS)
you could delete the program at the directory of C:\PARTS\
but the directory different as the different machine, you could find the correcttion directory as single phase said.
Any question alright? I glad to reply for you!
Old 03-29-2008, 06:10 AM
Thanks, worked great.
Found the file, deleted, all is well.
Help with Bridgeport Interact Series 1 MK2 Stuck on the Limit Switches mwibbels Bridgeport and Hardinge Mills 12 02-05-2009 02:33 PM
Need Help!- VM16 with CSM 11405-706 Radius Milltronics 5 03-29-2008 09:20 PM
Partner 1 Series G- CMOS display type mismatch life3970 Milltronics 0 01-31-2008 09:00 PM
VM16 Info elecbeaver Milltronics 1 06-22-2007 07:34 PM
VM16 CNC shutting down elecbeaver Milltronics 2 05-21-2007 06:22 PM
