Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 03-21-2008, 11:12 PM
fcycles is on a distinguished road
partner 1 z axis drifting , encoder???
Has anyone encountered this problem? Out of the blue while face milling a part the z axis started slowly diving down while the readout still shows the same position. I pulled the belt cover off to watch it as it runs , the servo is slowly pulsing back and forth very slightly and gradually starts diving the z down. Does This sound like an encoder issue? Or maybe servo brake? I pulled apart the servo and cleaned up the commutator and brushes - all looked good. But it didnt help. If the encoder was going out wouldn't the positioning readout shows changes? I appreciate anyones input
Thanks!
Old 03-25-2008, 06:17 PM
jpawelk is on a distinguished road
It sounds like the encoder is failing. Make certain that the encoder itself is connected tightly to the end shaft of the motor. It may also be the encoder cable as well. If the encoder is not giving feedback to the control, the axis can move and the control will not show the movement.
Old 03-25-2008, 08:39 PM
figured it out
I thought maybe that was the problem too , buuut Im an idiot , after i cleaned the tach up again with scotch brite it quit pulsing but i still had the same problem when ide face the material , turned out to be something in the aluminum that was very hard! It was starting a chatter and making it hog into it. Never ran into this at this extreme before, it was like they threw nuggets of carbide into the alumnium plate when they made it. Wont be buying there anymore!
Partner 4 Z axis issue ozturbo Milltronics 3 03-21-2008 10:29 PM
X AXIS DRIFTING +/- .005 WORKALONE Fadal 4 03-03-2008 10:10 AM
Z-axis drifting down Vogavt Machine Problems, Solutions , Wireless DNC, serial port 4 10-23-2007 03:04 AM
Router Z axis drifting down! cnctygrys Commercial CNC Wood Routers 3 08-13-2007 10:13 PM
XYZ Drifting Techteacher Stepper Motors and Drives 3 11-12-2005 10:04 PM
