Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 03-21-2008, 08:30 AM
JFDuval is on a distinguished road
Centurion VI : Error 505
Hello,
We are working on a Milltronics VKM3 with a Centurion VI panel. We now have a problem that gives us "Error 505: Radius too small to span given points" when trying to load a G-Code program. Last time we had this, a correction of the tool's diameter eliminated the problem. Now, we are unable to clear this error and we cannot complete our parts.
Please inform us about what is causing this particular error, and what workaround can be used.
Old 03-21-2008, 11:06 AM
jpawelk is on a distinguished road
An error 505 states that a radius is too small to span given points. Try using a larger diameter tool if possible. If using a larger tool is not possible, the program will need to be edited so that the start and end points are more than "R" distance apart.
Old 03-21-2008, 11:12 AM
Hello jpawelk,
Do I understand right that we need to eliminate the overlap in the circle we try to machinate?
Old 03-25-2008, 11:49 AM
Hello,
We still have the problem...
Is there a place where we can download a complete manual, with error codes and workarounds?
Thanks,
JF
Old 03-25-2008, 06:32 PM
Your start and end points of the arc need to be edited so that they are larger than the radius of the arc. Manuals are available through Milltronics parts dept. You can contact them @ 952.442.1401, option 3. Thank you
BAD V error on a Partner 6 Centurion 5 controller Kev13 Milltronics 14 12-09-2008 11:34 PM
Centurion 5 vs. Centurion 6 and validation codes Turbo VW Milltronics 2 02-11-2007 02:35 PM
How Do I Calibrate MY Centurion 6? TZ250 General Metal Working Machines 1 01-12-2007 09:17 PM
I'm Considering a Centurion 1 TZ250 Milltronics 9 09-07-2006 02:30 PM
Centurion 7 Enda Milltronics 1 01-25-2006 06:00 PM
