Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 02-20-2008, 07:26 PM
Brian FRF is on a distinguished road
Slipping bent in partner 5 with indexable?
Not sure if the belt is slipping or not. But its the only explanation I can come up with. Running a 2 flute 1" indexable in steel, good inserts. I cant run it harder than .120 depth, full diameter (slot) at 2500 rpm, and 15 ipm?
Running the spindle faster, it just pulls down sooner. It works for what its doing, but Id like to run harder. Both the manual, and the plate on the motor say 5hp. It is running on a professionally built and balanced phase converter. Heck if it was running on single phase it would still be 3hp or better.
Ive run 3/4 indexables .250 depth on older 2-3hp trees in steel and they cruise right though, so only thing I can think is belts?
Old 02-20-2008, 07:50 PM
mactec54 is on a distinguished road
Hi Brian FRF
What size is your phase converter you would hear the belt if they were slipping
Mactec54
Old 02-20-2008, 08:34 PM
Originally Posted by mactec54 View Post
Hi Brian FRF
10hp. The company we bought it from says that at under 80% its running at ~1-2% balanced. And at 100% closer to 5%.
I dont know if I could hear the belt with the indexable going I can barely heard the spindle slow. But Im not sure if Im hearing the spindle slow, or the motor slow.
x axis slipping FUN4ME Fadal 2 01-08-2008 02:20 PM
Y Axis Slipping ?? twocik Benchtop Machines 18 12-11-2007 05:11 PM
RFQ: Bent Aluminum Part lerman Employment Opportunity 4 04-21-2006 02:15 PM
RFQ- Need 3/32" wire bent CNCadmin Employment Opportunity 5 12-18-2005 08:32 PM
Bent ball screw?? TommyB DIY-CNC Router Table Machines 8 11-18-2004 10:03 AM
