Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 01-12-2008, 04:28 PM
drew_burg is on a distinguished road
Question Manipulating Rough Facing Cycle for ML22 w/ Centurion 7T
Here is what I am trying to do… On a rough facing canned cycle, I am trying to slow down the feed rate half way down the face of the part. I was using two separate line segments to create the profile of the face. On the second line, I inserted a feed rate instead of leaving it blank and letting it assume the inserted feed rate in the tool change. When the canned cycle executes, the roughing segments of the pattern stay at the feedrate set in the tool change throughout the entire cycle, but the finishing part (final cut) of the roughing pattern executes at the feedrate set in the tool change except where I change the feed rate in the line segments.
Here is my question… How do I get the roughing segment to use the lower feedrate in the roughing pattern when I have defined it like it does in the finishing segment of the roughing canned cycle?
I am a new Mitronics user… so any help would be greatly appreciated!
Facing problem with aluminium. alexccmeister General Metalwork Discussion 11 07-06-2007 06:55 AM
facing and tapping 304 stainless 1cnchogger General Metalwork Discussion 19 02-26-2007 09:18 AM
Centurion 5 vs. Centurion 6 and validation codes Turbo VW Milltronics 2 02-11-2007 02:35 PM
Pushin' ML22 murphyspost Milltronics 5 06-19-2006 04:16 PM
Facing impact General Metalwork Discussion 4 02-22-2006 08:24 PM
