Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 01-10-2008, 09:38 AM
Quadin is on a distinguished road
Partner 1 Tool Changer not rotating
Hi all,
We have a Milltronics Partner 1, Centurion V with a 12 postion tool changer. The problem we're having is the tool changer will not rotate CW or CCW. Everything else seems to work.
When you go to the tool changer page and try to rotate the changer CW /CWW, nothing happens and the control locks up. You have to hit the E-Stop and reset the machine.
We were thinking a proximity switch could be bad or possibly the motor.
Does anybody have a list of things to check? Wires/Voltages?
Or should I just call in the service guy? $$$
Mike
Old 01-10-2008, 04:04 PM
ProductionPal is on a distinguished road
Check the relays that control motor rotation (K21&K22) to see if they energize...if not you may have a blown fuse. Also check the prox signals on the tool changer. If the signal is not present to the control that the pot is retracted, the logic will not allow the carousel to rotate.
Old 01-15-2008, 08:23 AM
jpawelk is on a distinguished road
The fuses for the tool changer motor are 10 and 11. Also make certain that Y in 3 is a 1 in the diag screen. If it is not, the tool changer will not rotate as well.
Tool Changer Paul Petersen Fadal 2 11-14-2007 11:40 AM
Partner I Tool Change Problems Outlaw6700 Milltronics 2 02-25-2007 10:33 PM
tool changer motomitch1 Fanuc 6 08-10-2006 03:02 AM
Tool Changer Moondog Mach Software (ArtSoft software) 4 05-21-2006 02:34 PM
Tool Changer - How? creative_mind CNCzone Club House 17 08-30-2003 10:01 PM
