Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 12-28-2007, 10:42 PM
Brian FRF is on a distinguished road
Phase convert meets cent 4 and partner 5
89 model, cent 4 controller, partner 5 iron. hooking up production rotary phase convertor. One "FLOATING" leg. Naturally I only want the one wild leg going to the motor, none of the transformers, controllers, etc. Looking at wiring, looks like I want the wild leg on line 3. and reconnect a couple things to other legs (electric lube, a 115VAC leg and a 110VAC outlet for high speed spindle)
Anyone wired up one of these things this way?
Old 12-29-2007, 12:17 AM
Dave1's Avatar
Dave1 is on a distinguished road
My Cent 5's, Partner 1 and 6 are both running off single phase. I ran the incoming line to L1 and L3 IIRC. It's L1, L2, L3 I did not run any power to L2 (the middle line). I don't know how it works or if it would work like that on yours but on mine I think the only thing that actually needs 3 phase is the spindle motor, my axis drives are dc anyway.
Dave
Schneider Machine
A force of one
Old 12-29-2007, 05:39 PM
lotsa luck is on a distinguished road
I run mine also on single phase. The old spindle drive required 3 phase but when I had to replace it the new one does not need 3 phase so why bother with the phase converter anymore.
Old 12-29-2007, 09:13 PM
Dave1's Avatar
You know what's really weird, I'm pretty sure both my spindle drives are 3 phase, I'll have to double check but I'm pretty sure they are. One's a Safetonics G3 and the other is a Magnetek GPD515 which replaced a G3 after all the magic smoke fell out
Figure that one out.
Dave
Schneider Machine
A force of one
Old 12-30-2007, 07:23 AM
My original one (long gone) was also 3 phase but many/most others can be run from single phase.
Can I convert single phase motor to three phase? Jim Estes Phase Converters and VFD 30 01-24-2009 02:41 AM
Cent 4 on partner 7 VMC smts Milltronics 0 12-19-2007 11:29 AM
cent 6 I/O HANSENTECH Milltronics 4 12-03-2006 04:27 PM
Cent 7 Program an elipse?? out**cold Milltronics 1 10-25-2006 08:33 AM
Convert Step/direction to phase drive jderou Stepper Motors and Drives 18 08-05-2005 08:52 AM
