| Milltronics Discuss Milltronics Machines |
Yesterday marked the 3 week point of my new RW15 mill from milltronics being under power , 240 hours and I am very pleased overall. My only complaints at this point are probably fairly minor, there is a pretty constant flow of coolant running across the floor when the machine is in use, about 3 gals lost every 8 hour shift , makes for a very slippery and unsafe work space around the machine. I cant find the leak, it doesnt appear to be plumbing related. The only other issue is a part fell out of the head onto the table yesterday that looks like one half of a 5/8" ball bearing , will post a pic later today. Update as of dec 11th No one at milltronics can identify the mystery part in the pic below, Time will tell if its a critical part . Although I am very happy with the size , accuracy and performance of the RW15 , the table is very soft and is unhardened. Its much softer than any cast iron I have encountered . Based on this I dont believe I would purchase this machine again . I am planning to add another similarly sized machine in January and was hoping/planning to purchase an identical unit but this extremly soft table is just not acceptable for a work surface on a machine tool in my opinion . 4 other members here have contacted me with the exact same complaint Last edited by panaceabea; 12-11-2007 at 08:09 PM. |
| LOL, that can't be good! Seriously though, you know I am only teasing, my VM15 has never laid any eggs like that. I am sorry but it just strikes me as funny (I am sure you are not laughing). ![]() This reminds me of what happened to me last week. I was drilling some titanium and the bit locked into the stock. The head went up and left the tool holder, pull stud and bit sticking in the stock. That would not have been so bad but before I could hit stop, the head came back down and smashed the pull stud into the BB retaining device up in the head. It did not damage anything as far as I can tell but I felt pretty stupid and I half expect to be seeing parts falling out of my VM-15's head soon!I hope you find out that the part is nothing important. The RW15 looks like a great machine for the money. I would love to have one. The only thing I can think of to try to find the leak is to pull out the tank and spray inside the machine with a hose while looking under neath. Cheers SF |
| guys, I just recently became familiar with these machines. Are they worth having for light production work? What do they cost? Where can I get real work info on them on how they perform? We need one very soon and about to pull the trigger on an older machine but saw these and they "look" nice. Can someone please call me if time permits to talk about them. Thanks Brandon 316-992-6984 |
| One thing I am noticing on this machine is the table casting is extremly soft, I have owned a variety of US made and imported machine tool for about 25 years and this is by far the softest cast iron surface I have ever encountered. Maybe this table just missed the hardening stage on the line . I am very careful about cleaning the table , all clamps fixtures etc and using sheet pvc under clamps or pretty much anything that comes in contact with the table other than big surface area items like the vice. I do lay the vice handle over on the table occasionaly when running short operations of a minute or less . I dont drop the handle but gently place it on the table , but this morning I noticed 100+- little indentations where the ball on the vice handle has made contact with the table, no dropping, just gently placing the handle on the table, a drop of no more than 1/4" from my hand to the table. I can also see clear evidence where the tnuts are sinking into the bottom of the tslot when I tighten a clamp. I also noticed a dent in the table from a single small aluminum chip that got caught under the edge of the vice I dont know where this is much of an issue or not but it is bothersome to me that the table on a machining center intended for thousands of hours of use wouldnt be any harder than a cast iron bull wieght |
| I do not have a hardness tester or I would test my VM-15 table that was made in 1998. It's table is not soft and has stood up very well over the last 10 years. I am careful with it but I never put any plastic on it to protect it. The t-nuts do not mark the inside of the slots either. I bet your machine is really accurate. What does it have in the backlash parameters? Are you happy with it's size? What kind of parts do you make? Cheers SF |
| I just dropped the vice handle on my bridgeport table from 6 " and not a single visible mark , I have to drop the handle from 14+ inches onto the cast iron table of my chinese table saw to get a dent like the ones on the milltronics table created by letting the handle gently roll out of my hand. The table on my import mill is drasticly harder also , I do not believe the milltronics table to have been hardened at all, doing the drop test on a dead soft large chinese cast iron angle plate with the same handle they seem about the same hardness, dings with 1/4-1/2" drop, I can live with the coolant leaks but this soft table issue really bothers me, just never had a work surface on any machine tool this soft The machine is very accurate and I am very happy with the size and work area, I mostly make conversion parts for the little sieg benchtop mills , power drawbars for bridgeport clones and gun related parts. Here are a few pics of some of the parts ![]() |
| I am thinking I should run away from the Milltronics line. I really thought they were MUCH cheaper than others but after shopping, they are in line and I would rather pay 5K more and get a Haas. I like a few features but was really thinking they were like in the 20Ks brand new or something. Yeah right. I guess it is Christmas time! I guess if one shows up on my door step, I will accept it with love and open arms. |
#10
| Panaceabea, I thought I was the only one. We have to say something about this to Milltronics. I've had my RW20 for less than 8 months, and can't believe the small dents in the table. It is surly soft. Please contact me.I sent a PM to you. I really need to talk to you about this. Milltronics should warranty this problem. Last edited by Numeric Concept; 12-06-2007 at 06:33 PM. Reason: Forgot recievers name |
#11
| I sent you a pm, the guy from Milltronics is looking into and going to contact me Monday. The top pic is of scope rails for the receivers in the lower pic. The rec in the lower pic are for the FN PS90 rifle (the gun in the stargate show) |
| Milltronics RW15 | TR MFG | Milltronics | 7 | 05-06-2010 07:03 PM |
