Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 11-09-2007, 03:35 PM
TZ250 is on a distinguished road
Adjusting Backlash Compensation on a Cen. 6
Guys,
How do I adjust the backlash compensation of my Centurion VI? When I switch directions with the handwheel, the indicator needle jumps .0015".
TIA.
Rob in Ohio
Old 11-09-2007, 04:46 PM
One of Many is on a distinguished road
Utilities>
Parameters>
Setup>
Level> Validation code= Proto3> Level=3>
Axis> scroll down till you can edit the Backlash>
Edit> then select axis to edit.
Before you arbitrarily make that change, check the backlash in several places on the screw. I have found if an axis jumps on reversal, the backlash may be set to high for no load indicator readings. While cutting, it can be quite different. I have also found that there are some anomalies with the handwheel resolution verses the table motion with small moves(one detent) of the handwheel. Possibly binary math wherein one pulse change does nothing but the next makes up for it. Either that or the detents do not line up as well as one would expect with the actual pulses.
Doing a circle, diamond, square, test program can clarify which axis has excess backlash or too much backlash compensation.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 11-09-2007, 07:07 PM
Wow!
DC, thanks for the information. I had not considered the load on the table.
How do I (or who do I call to) calibrate the machine? There is a method that has a Renishaw probe that measures the axis variation of a interpolated circle.
I'd rather do that. How much would that cost?
Thanks again.
Rob in Ohio
Old 11-09-2007, 08:31 PM
There are plenty out there.
CNC Calibration
The machines are +/- .0004 as new repeatability. The best you can do is re-map the screws to update the ballscrew compensation for wear.
Cost? very subjective to the mercy of the provider.
DC
Adjusting crossfeed backlash on Busy Bee chardinej Mini Lathe 0 08-29-2007 09:15 PM
Backlash compensation at GE MC2000 bobecm General CNC (Mill and Lathe) Control Software (NC) 0 06-07-2007 07:30 AM
Backlash Compensation utengineer04 General Metalwork Discussion 5 04-26-2005 11:42 AM
Adjusting backlash on VF-OE eddie Haas Mills 7 12-22-2004 02:20 AM
