Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 10-31-2007, 12:51 PM
br1 br1 is online now
br1 is on a distinguished road
Partner VM17 issues
I am having an issue with our Partner VM17 (yes it is an oldy) the issue is with the handwheel axis move. It seems to be stuck going in positive in all axis, I have replaced the hand wheel encoder, and even went as far as pull the memory (brains) out and sent to Milltronics. (which I must add they were really speedy 1 week). They benchtested them made a few adjustments but still I have this problem. It worked good for say 1/2 hour after I hooked them back up then I turned it off and went home for the day only to come back the next and have this nagging problem. By the way the Jog function works fine, Any suggestions would be most welcome. Thanks
Old 10-31-2007, 03:30 PM
One of Many is on a distinguished road
Sounds like a wiring or connector issue may be contributing to a high resistance to the signals from the handwheel to the control inputs.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 11-04-2007, 01:58 AM
bborb is on a distinguished road
You've pretty much ruled out the control and the handwheel unit, that leaves everything in between..........everything from the socket you plug the unit into, to the connector that attaches to the control. Visually inspect and/or "ohm out" this section to verify its integrity.
Old 11-13-2007, 08:57 PM
milltronicsmark is on a distinguished road
br1
Try disconnecting the CRT plug in the back of the power cabinet. It is on the lower right of the computer case. My Partner VI did the same thing and it was a loose CRT connector. Hope this helps
Old 11-14-2007, 08:57 AM
Thanks I will try this
Partner 1 toolchanger martsto Milltronics 3 11-04-2007 02:05 AM
Partner 4 service dgula Milltronics 1 10-06-2007 12:30 PM
RS232 connection issues to Milltronics Partner V Jeff S Milltronics 3 03-16-2007 06:34 AM
Partner IV E-STOP Ben Colby Milltronics 9 01-03-2007 12:02 AM
Milltronics Partner IV Ben Colby Milltronics 6 03-27-2006 04:53 PM
