10-30-2007, 10:15 PM
Remove the fibreglass cover on ther tool carousol so you can observe the air cylinder that swings the arm . Your air should be at 85 PSI. You may have an acccumulation of air tool oil in the cyl that prevents it from going the full stroke . There is a prox sensor on that cyl the sends a complete signal to the control to activate the tool chg macro .
The spring buttons that hold the tool in are causing the additional pressure that prevents a full swing also .
You may have to disconnect the air supply and then remove the air lines from the cyl , and manually swing the arm to make sure the cyl will run its full stroke .
There is also an adjustment on the outer end of the cyl so you can loosen the attaching yoke and screw it out to get a bit more swing of the arm . You will have to remove the pin on the arm end so you can screw it out . This was not quite enough in my case , so I wound up making a shim pack 1/4" thick to put under the fixed end , and that gave me the extra stroke I needed. Pretty serious stuff if the z retracts before the tool is snapped into the holder . I also had to increase the delay time between tool release and Z retract so it wont rip the tool out of the carousol .
Note that there are adjustable inline valves on the air lines to control the speed the arm swings . These are VERY sensitive , so be careful if you adjust them . I made the arm swing so fast , that the sudden stop made the tools fall out of the carousol .
Best of luck , I have 2 partner 1's about the same age , and they produce tons of work . BTW if yer CRT screen craps out on ya , don't ever try to fit a generic screen inside . Tried that , and fried 2 control boards at $1000 each , just go to tiger direct.com and get a 14" lcd screen and make a tin box to attach it to the outside of the control box. |
