| Milltronics Discuss Milltronics Machines |
I'm trying to run a program from my pc into the rs232 port on my milltronics centurian 1 . the program is to long to run off the floppy disk drive. Does any know how I hook up my pc? What do I use to feed the program from my pc (software) to the mill? sincerly, bruce |
You must setup the serial port so that the handshaking, whether it be hardware or software, can be controlled by the machine you are sending to. If the destination machine can 'throttle' the data being sent, which most can, (and no characters get lost), it might be as simple as COPY gcode.xxx COM1: or watever port. If the destination doesn't like breaks within a line, a simple Visual Basic program could make sure a line is not sent until the destination buffer has enough space for the line (including CRLF)
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| Start Hyperterminal (windows communication accessory) Click File, New Connection Choose a name for your settings. This will become a file name.ht Later on, double clicking on this .HT file should start Hyperterminal with all the same settings. Select Connect using Select Direct to Com1 or whatever. Click OK Now match the settings in your PARAMS-CTRL in the CNC menus Select Bits per second Select Data Bits Select Parity Select Stop Bits Select Flow control Xon / Xoff <<<IMPORTANT.>>> Click OK Now start fiddling with Transfer Try sending and receiving When you exit the program make sure you say yes to saving the settings. If you link pin 2 to 3 on the PC you can send files to yourself to make sure something is happening. Just typeing some characters should echo back to the screen. Depending on Hyperterminal setting (echo on) if the character you type is X then XX will appear. With echo off you wont get doubles. You Porbaly have to hit CTRL-Enter for a new line. Using a multimeter, if you measure the voltage on pin 2 and 3 you will usually find one close to zero volts. That's the Receive line. The other will have a much higher voltage. Between 7 and 12 (probably negative). That's the Transmit line. The negative of the multimeter connects to pins 7 or pin 1. Usually the shroud is OK. The receive line at each end is connected to the transmit line at the other end. Good luck!
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. Last edited by neilw20; 10-16-2007 at 01:04 PM. Reason: typos |
| Mill trips in middle of running | cut2spec | Benchtop Machines | 1 | 02-27-2007 07:19 PM |
| WEST TEXAS - running fanuc mill - need help - will trade for machine time | bcdracing | Mentors & Apprentice Locator | 4 | 01-12-2007 07:27 PM |
| Mach3 running my mill drill using the G203 Vampire drivers | Dan Mauch | Benchtop Machines | 0 | 11-15-2006 01:15 PM |
| Test Running the new G230 Vampire drivers on a mill drill | Dan Mauch | Gecko Drives | 2 | 11-12-2006 08:58 PM |
| running a bridge knee mill | MBG | Bridgeport and Hardinge Mills | 3 | 06-12-2005 09:44 AM |
