Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 09-20-2007, 09:28 AM
M_Controls's Avatar
M_Controls is on a distinguished road
Trouble with replacement lube pumps
Milltronics ML-20 CNC lathe, 6 yrs old: I had to replace the main lube pump due to electrical corrosion caused by coolant getting in to the pump electronic controls. The next two replacements - direct from Milltronics - quickly failed, in less than a month each, the pumps would go crazy and just keep pumping too much oil at irregular and reduced intervals, regardless of the pot setting. The first replacement I sealed as best I could using silicone, including the audible alarm wires. It still got just a tiny bit inside. The second was completely dry inside when it failed! So I had to replace the uinit with a Bijur mechanical timer unit (model TMD-1; 26350-1) that is better sealed against outside contamination. Unfortunately though, this unit does not have an audible alarm; it will only alarm (the machine control) when the automatic cycle (other than homing) is attempted. Note to those who do this: you must flip the float to change the switch state.
Found surplus pumps for vacuum forming kayaker43 Vacuum forming, Thermoforming Etc 0 06-13-2007 11:53 AM
Which way lube oil? WilliamD General Metal Working Machines 4 02-26-2007 08:46 PM
Lead screw lube amount. servo belt replacement bob1112 Linear and Rotary Motion 2 11-24-2006 06:59 PM
Building special 5-axe CNC for production impellers of centrifugal pumps softsx General Metalwork Discussion 0 10-17-2006 12:45 PM
Lube monte55 Linear and Rotary Motion 2 09-17-2006 04:42 PM
