| Milltronics Discuss Milltronics Machines |
I am wanting to go from the old rs232 hook up on my Milltronics to a network card. Anybody know if I can use a regular network card or do I need the $400.00 card from Miltronics. I haven't even looked in the back yet. Also had a tool maker say the rpms are wrong on the spindle need some help on this one to. |
| You don't even tell us what control is on the machine. You haven't even looked inside the control yet? Available slots? (ISA? PCI?) Is there a hard-drive? Flashcard? Is the software on EPROM's? SIM-Disk? Do you have an external keyboard? Is there a floppy drive? Do you have DOS network card drivers and DOS networking software? Additional RAM may be required, do you know how much and what type? I've installed "off the shelf" network cards in Milltronics controls but I don't suggest you try it. Spend the $400 and save yourself some headaches. - - <had a tool maker say the rpms are wrong on the spindle need some help on this one to> Fire the toolmaker (LOL) or What was the spindle programmed at? What was the spindle override registering (not "what was the knob set at")? What was the toolmaker's tachometer displaying? What frequency was displayed on the spindle drive? Does this spindle have a high and low range? Generally inaccuracies can be adjusted through the parameter(s). |
Jetski |
| I was a toolmaker before I got into the CNC install/repair side of things and I didn't know any of this until someone showed me. I'd never seen a RAM..... I did have a bull chase me once for throwing rocks at it (how stupid is that?) So you have an IT guy? I'd like to have a discussion with him or at least have him "in the loop" as they say. For the spindle speed: First make sure you've registered the proper spindle range in the control> [Util] [Parms] [Ctrl] and cursor down to Spindle Range, then toggle to the correct spindle range the machine is in. Escape back to the main screen. Have you ever typed PROTO3 into your control? Last edited by bborb; 09-17-2007 at 05:39 PM. Reason: typo |
| Use to service, and Training on Okada high speed graphite mills, and do training on Hurcos. Just no experience on the Miltronics. Advanced machinery sent me a quote on updating with a SBC Mother board 1,700.00 upgrade to 256 meg of ram 400.00 and networking 400.00. I am just unsure and unstable. Very different from the Hurcos and Fanuc 160i I am use to. I have been to the proto3 to do some backlash comp a year or 2 ago. I want to use the machine more like the VM1 Hurco beside it (short of tool changes). I have been teaching myself the controls slowly (Hurco crutch gets in the way alot). I have adjusted parameters on Fanuc, use to do ball bar testing also. Hey if you get a chance tomorrow send me a direct email to gsilberberg@progressive-plastics.net and give me your phone number. I will give you a call around 11:00 or so Indiana time. Save time and finger work. Thanks for the call back. |
Sorry Jetski I don't have the answers to your questions. I just got a Milltronics machine myself. Not to rain on anybody's parade or anything, but it would really cool if discussions like these did not get taken off the forum to the phone. Yes it's easier and more convenient, but it also doesn't "share the wealth" of knowledge. I'd love to see the answers to these questions as I'm sure I will have the same questions once I get my machine up and running. Thanks, Michael |
| I'd also like to know the procedure. Not that I have the time to fight with it to get it working via DOS, but I am surprised there is not a basic process or shareware self configuring file that I have found that could set up DOS box to Windows box networking. Here is what I have run across, so if you choose to take on the challenge given the ultimate goal, just think of the amount of effort you save the rest of us! DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
| Hi Radius, I pointed out the use of the validation code PROTO3 to setup access level 3 parameters. In the [MISC] settings there are spindle parameters you can adjust to make the commanded spindle RPM's match a technician's tachometer readings. I also mentioned a hardcopy of both the machine parameters and the spindle parameters (for the Yaskawa spindle drive) are in the electrical cabinet (these are CRITICAL, DO NOT LOSE). Then we swapped war stories, such as Boeing moving away from using aerospace aluminum and starting to make their planes out of a newly developed plastic. |
Unfortunately for me, I believe the machine and spindle parameters that are supposed to be in the electrical cabinet are gone. The machine I have is a '96 VM-16 with centurion 5. I bought it as a project machine and boy is it a project. The bridge rectifier for the servo drives are missing, the big filter caps are disconnected, all kinds of wiring has been disconnected, fuses pulled, etc. At least I have some basic schematics for this machine.When I get ready to seriously tackle this you can bet I'll be here with questions. |
#10
As far as I know, AFAIK, the computer is a regular Pentium motherboard. You should be able to install a regular network card, just have a look and see if you'll need a PCI or ISA card. By default, the MB-19 uses NetBeui for network protocol. This is what I use. You'll have to install NetBeui if you are using XP. I think there's an option, on the MB-19, to change to TCPIP, but I haven't tried it. I think I would load the network on the Milltronics and see what network cards are supported and get one of those. Once you install the card, just follow the directions from Milltronics. I'm not sure about the RPM problem, if there really is one. enat |
#11
| I just checked the setup program on the mill and there are a boatload of cards supported. I'm going to take a guess that they are ISA cards. You may luckout and the network card will work with having to guess what interrupt it needs to be. enat |
| Hurco network card | Piobaire | HURCO | 1 | 08-22-2007 10:24 PM |
| Mach 3 Wireless Network Card Interference | bill south | Mach Mill | 5 | 07-13-2006 02:25 PM |
| Wireless network to CNC | WayneHill | Computers and Networking | 1 | 03-02-2006 12:29 PM |
| network surf help | turmite | Rhino 3D | 2 | 01-20-2006 09:48 PM |
| cnc network | chips2000 | Computers and Networking | 5 | 10-10-2004 01:40 PM |
