Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 07-25-2007, 01:42 PM
dcrblazer is on a distinguished road
need some help
i have an rh30 vmm and we are running a program with 2 vices on the table our machinist is out for a while (injury) and i am "trying" to run the machine. i have been a programmer for this machine only and it is my only experience with machining. with the machinist out i realize how valuable he is. now to my question: we have a g54 and a g55 that cut the same part twice how do i tell the machine that there are separate z values for each vice. i saw in the parameter-offset menu a way to set a z offset but how do i set the tools in the first place for the different g54/g55 settings
thanks
John
Old 07-25-2007, 03:12 PM
wcopley's Avatar
wcopley is on a distinguished road
what control
Old 07-25-2007, 03:30 PM
sorry its a centurion 6
Old 07-25-2007, 11:19 PM
single phase's Avatar
single phase is on a distinguished road
Set the x and y for the g54 for the first vice and then set the x and y for the g55 for the second vice.
look at the main-parms-coord, there are work coordinates there. Make sure the z component of the work 1 and work 2 coordinates are zero.
Do a g54 and touch off all your tools normally on the first vice. With one of the tools go over to the second vice and measure what the z difference is.
go back to the main-parms-coord screen and modify the work 2 coordinate z value with that difference.
check that you got the offset in the correct polarity; do a G55 and go over to the second vice and make sure it is correct.
Cheers
SF
Old 07-26-2007, 09:19 AM
thanks single phase thats what i thought i needed to do
thanks guys
