Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 07-06-2007, 01:02 PM
TZ250 is on a distinguished road
File Extension Question
Guys, what is the file extension for a Centurion 6 (floppy drive)?
I'm trying to write some programs via CAM software. So far, the mill doesn't recognize that a program is on the floppy. The floppy was formatted prior to using it.
Thanks in advance.
P.S. Please tell me any other advice that you think I'll need to get the mill to read files.
Old 07-06-2007, 02:10 PM
moldcore is on a distinguished road
.ncc should work
Old 07-06-2007, 09:06 PM
bborb is on a distinguished road
There is NO file extension.... just O1234. or P1234. (for conversational progs).
You can enable the parameter "Full DOS File Names" and it will read ANY FILE on the disk, but be careful not to try and read anything other than a gcode file in ASCII format or it can lock up the control or scramble parameter(s). In other words, don't try to read an .exe or .jpg file.
Old 07-07-2007, 02:25 PM
How do I save a file with no extension?
I opened the .txt file in Notepad, then tried to save it with no extension. I think that it was saved as a .txt file.
The controller didn't recognize the .ncc file either.
Maybe I should switch to "Full DOS File Names".
Please advise. Thank you for your help.
Old 07-07-2007, 04:03 PM
One of Many is on a distinguished road
Just rename it as O#### without an extention. You will get a warning about changing file types, but ignore that.
If this is the first run posting from your cam package, verify it on the control, then run it dry without cutting tools to be sure it runs as expected.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 07-07-2007, 04:50 PM
SKEETO's Avatar
SKEETO is on a distinguished road
Check you folder options on your pc. Make sure they show hidden files so you can rename them without ext.
Old 07-08-2007, 12:29 AM
Dave1's Avatar
Dave1 is on a distinguished road
You don't even need an o (oh) in front of the prog number. My controls are switched to use full dos file names. I use floppy's with only programs for the machines. The only tome you need an o (oh) is for calling sub programs.
Dave
Schneider Machine
A force of one
Old 07-08-2007, 09:55 AM
You are forcing the .txt extension in notepad because you didn't change "File Type" in the flip out pane to "*.* All Files", you've left it as File Type *.txt
These are found at the lower area of the window that pops up when you select "Save AS"
Old 07-09-2007, 07:08 AM
LYN BYRD is on a distinguished road
Change File Extension
Check Your Cam Software Too See If You Can Change How It Is Saved. That's What I Did. Just Save It With The Period And No Extension. Hope This Helps.
Old 08-05-2007, 08:30 PM
Guys, thanks for your help so far.
My mill still doesn't recognize the files on the floppy. I can change the 'Save As File Type' to all files, but it wtill writes a text file. I don't have an option for ASCII encoding.
When I look at the program from Explorer, it is still a text document.
Thanks for your help.
  #11   Ban this user!
Old 08-05-2007, 08:55 PM
Woohoo! It now reads the programs on the floppy!
I had made many changes, but had not added the period at the end of the file name.
Thanks guys!
What is a M3P extension bill south Mach Wizards, Macros, & Addons 4 08-01-2007 12:56 PM
question about file converting cncmachiningzon Solidworks 1 04-14-2007 10:51 AM
post file extension GRANDPA Mastercam 3 03-21-2007 10:44 PM
Extension Cord dneisler Welding, Brazing, Soldering, Sealing 4 01-13-2006 07:29 PM
Log file question... murphy625 CamSoft Products 9 04-05-2005 04:12 PM
