| Milltronics Discuss Milltronics Machines |
| You may be able to set it up as an indexer using spare M codes, but I have yet to find any of the older controls that do full 4 axis motion. This one shows a Haas 4th axis was connected. http://www.surplusrecord.com/cgi-bin/adpop.pl?552911|P How did the RGB monitor test work out? DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
| Look inside your cabinet. Your motherboard is on the door, across from it in the cabinet are your drive cards. There is a fan perpendicular to the cards. The first three are XYZ, if you have a 4th card this would be used for your 4th axis. If you don't have a 4th card than it's a no go, unless you can some how find another drive card? Did you get your communication problem sorted out? Ben COBRO MFG |
| I have a true 4-axis SMW table on my Cen 4 machine. Ben is right, look for the amp card. The company that did the amps are still around and can repair the cards if need be. They told me that if I had more then like 2 cards for repair then it would be more cost worthy to upgrade the amps. |
| A 5-axis CNC machine including a rotary axis | synthetiklone | CNC Wood Router Project Log | 11 | 05-23-2012 09:31 PM |
| the Difference of 2-Axis and 3-Axis of Vertical Mill Machine | begacon | Knee Vertical Mills | 6 | 07-30-2009 06:31 AM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 02:58 PM |
| Options for 2 Axis Head (to make 5 axis) | drewgarth | DIY-CNC Router Table Machines | 6 | 07-12-2006 12:37 AM |
| DIY CNC: Gallery for z-axis, y-axis etc designs | bigz1 | Suggestions for the CNCzone.com site. | 6 | 05-23-2006 01:46 AM |
