Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 05-11-2007, 03:52 PM
schrupphobel72 is on a distinguished road
Question Buy new Milltronics or what else???
We are looking into buying a new CNC Vertical Milltronics Milling machine. Can anyone tell me if that would be a decent buy? Any thoughts on the Control?? We will be using it for mild Steel and 410 Stainless.
Old 05-11-2007, 04:33 PM
wcopley's Avatar
wcopley is on a distinguished road
What model ? we have the centurion 7 control I like them
Bill
Old 05-11-2007, 04:49 PM
we thinking about the Rh 30.
Old 05-11-2007, 04:54 PM
wcopley's Avatar
Cant be of much help on that model we have a RW20 and a VM30XP
I can tell you that we have had great support from our dealer and Milltronics
Bill
Old 05-11-2007, 09:18 PM
LYN BYRD is on a distinguished road
Milltronics
Been Using Milltronics Since 1997 And Am Very Happy.
The Service Guys Are Allways Eager To Help When The Occasional Challenge Comes Up.
Old 05-12-2007, 08:19 PM
pixburghenat is on a distinguished road
I use a MB19, great machine. The rh30 looks great too.
The only complaint I have is with the coolant pump, too small, have had to rebuild it twice. I'm thinking about adding an external coolant tank with a skimmer.
enat
Old 05-24-2007, 02:30 PM
gnielsen is on a distinguished road
milltronics compared to Haas or Fadal
How does the Milltronics compare to a Haas or Fadal as far as capabilities, accuracy and dependability. We build prototype to short run injection molds mostly from P-20. We have a Haas VF-1 that is a little over a year old and is fantastic compared to our 10 year old Fadal which we want to replace. Can I expect the same results out of a Milltronics VM30 that we get from our Haas?
Old 05-24-2007, 05:34 PM
captainasty is on a distinguished road
Smile
I'm glad some can get help. Milltronics are a great buy for the money BUT they only support their machines for about 10yrs. I have a Partner 7 w Cen 4 controller and I'm SOL for parts and support. When we bought the machine, we had to replace the spindle bearings, no problem, but then we tried to get a drive belt and where told "sorry discontinued". Luckly the machine is still running good.
Old 05-24-2007, 06:04 PM
AMCjeepCJ's Avatar
AMCjeepCJ is on a distinguished road
I cut 410 SS no problemo on my VM-22 quite regularly. As far as accuracy, I built a 300 series motorcycle wheel (18" x 10+") awhile back and at 180mph+ on the balancing machine it still didn't require weights... Considering this wheel was cut at three different times on my machine, (totally removed in between,) I'm thinking it was spot on~ You just don't get lucky like that, it had to be accurate... (The dude that owned the balancer was really impressed!)
BTW, that was a full 3D wheel...
Gimpy aka 313 (three thirteen)
The early bird may get the worm, but the second mouse gets the cheese.
Old 05-25-2007, 11:12 PM
single phase's Avatar
single phase is on a distinguished road
pictures of the wheel please!
  #11   Ban this user!
Old 05-26-2007, 06:10 AM
SORCHEROR is on a distinguished road
i would buy a hass before a miltronics,ive owned a miltronics years ago and now have a new hass,the hass is a much better machine and the service is
great
steve
  #12   Ban this user!
Old 05-28-2007, 12:21 PM
Farmers Machine is on a distinguished road
Get the RH 30. I have one with a tilting rotary 5 axis. there are no problems to speak of. I used to run a Haas VF7 and it cant stand in the shadow of the milltronics. There were always problems with the servo drive modules and it was very expensive to repair. My RH 30 was new in July of 2001 with about 8000 hours and still holds tenths all day every day. I am looking hard at the bigger RH 33 to do oilfield parts on. The RH 30 cuts 4140 and 316 stainless about 80% of its life. It has the 6000 RPM spindle with massive torque, but it is slow on aluminum, who cares when you work by the hour. You will not find a better service and support department with any other manufacturer. Or in stock overnight delivery of parts with a very knowledgeable parts dept. Very complicated parts can be programmed right at the control or you can use cad cam it works with either very well. you are not stuck with a cookie cutter style of machine with Milltronics you have a lot of options to build a machine to suit your specific needs and make a profitable work day.
Milltronics upgrade steedspeed General CNC (Mill and Lathe) Control Software (NC) 0 10-14-2006 09:38 PM
Milltronics Centurion Six CUTRITE Milltronics 10 10-13-2006 01:48 PM
Milltronics support harttool Milltronics 1 05-18-2006 06:00 PM
New Milltronics Owner Teps71 Milltronics 22 04-21-2006 02:55 PM
Milltronics AMCjeepCJ Suggestions for the CNCzone.com site. 2 12-21-2005 12:48 PM
