Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 04-29-2007, 06:59 PM
dshowald is on a distinguished road
tapered hole
any suggestions on programming a tapered hole in conventional programming?i know its easy enough but having a brain cramp.
thanks
Old 04-29-2007, 10:42 PM
Colin is on a distinguished road
Lathe?
If a lathe, it is G1 first diameter X?? to second diameter X?? and new Z??
Colin
Old 04-30-2007, 08:31 AM
dave3431 is on a distinguished road
What machine and control are you using.
Dave
Old 04-30-2007, 04:16 PM
milltronics mill with a centurion 7 control
Old 04-30-2007, 08:00 PM
LYN BYRD is on a distinguished road
Hole
Are You Milling A Hole Thru A Plate?
What Is The Angle Of The Taper?
Old 05-01-2007, 11:19 AM
AMCjeepCJ's Avatar
AMCjeepCJ is on a distinguished road
Smile
Did you mean conversational??
Goto your 'mill' start page and toggle through options... You'll have to program the hole as a 360 degree arc... If you're going to use multiple holes then do this step as a subroutine and call it up on another program...
My program kept crashing so I couldn't find it under the automated routines but if you look, I'd bet money it's an option on one of the start pages at the bottom...
Otherwise, if you meant regular G-code, I don't have a clue... It's so stinkin' easy in conversational that I never bothered to learn the hard way...
Gimpy aka 313 (three thirteen)
The early bird may get the worm, but the second mouse gets the cheese.
small tapered slots barnesy General Metalwork Discussion 3 04-21-2007 05:14 PM
Tapered gib chevdrgtrk General Metal Working Machines 4 11-28-2006 01:56 AM
Tapered Bore? dwarf66 General Metalwork Discussion 2 11-23-2006 02:56 PM
Tapered pockets with V19....tutorial? Bloy2004 BobCad-Cam 0 03-30-2006 10:13 AM
Setting up a tapered cutter cybeeria General Metalwork Discussion 4 03-20-2006 08:16 PM
