Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 04-10-2007, 04:50 PM
sujeet_nayak is on a distinguished road
Help required PCB drilling and milling cnc
Dear All,
I am browsing this site for a couple of months and found it very helpful. It was really amazing to find so many things happing here.
Finally I decided to make my cnc for drilling/milling PCBs.
Can anyone provide some tips on this.
I want to have work area 12 x 12 inch at minimum and plan to use T-Slots and linear bearings with moving gantry.
1) What should the size of t-slots 80x80, 60x120 for x-axis ???
2)Should I use shaft/shaft support/open pillow blocks or Precision Profile Rail Systems.
3)Should I use one lead screw or 2 leads screw(belt-driven) for x-axis.
4) I somewhat like the bungard cnc but it is out of my reach. Does anybody explain the x-axis system of bungard. I could not figure out exactly.
5) It is possible to buy a slim motor-integrated spindle cheaply for pcbs.
As this is going to be my first machine, please help me in taking decisions.
Thanxs.
Old 04-10-2007, 09:55 PM
kowell is on a distinguished road
For PCB making , Milling is not that good.
TRY THIS:
Hacking A Printer To Directly Print PCB's
Kym
Old 04-11-2007, 04:42 AM
kiwichris is on a distinguished road
TRY THIS:
Kym
I think that's a bit of a broad generalisation....
Milling PCB's is a good way for an electronics hobbiest to make PCB's without chemicals, if that is what they want to do... With a moderately accurate CNC router/mill you can make very functional PCB cheaply.
(I don't actually do either, I get my PCB's made by a commercial PCB fab. house...)
Old 04-11-2007, 08:51 AM
Kiwichris
Well having milled a few PCB,s myself and then using direct inkjet printing
of PCB's. I Know which i prefer: This method gives a much better finished
product and is a lot less costly than building a mill to machine boards.
Yeah don't like them chemicals myself, but results speak for them self.
Kym
Old 04-11-2007, 05:49 PM
Well, I make board using toner transfers and wanted some easier process. Hence I talked about milling. But my boards needs to be drilled also (most of them are 0.8mm ). It is a tedious job to make large (200-400 ) number of holes using hand drill/drill press. CNC PCB drillers are better choice as switching to surface mount components is not always a viable solution for me.
Hence I decided to make a m/c for this purpose only. With so many expert here I expect a little guidance for my first project.
I know about direct PCB printing.It's a superb option. But I will get my hands dirty after this project.
Smooth motion required high feed 3 axis surface milling cncjoy Fanuc 11 10-13-2007 02:03 AM
PCB Milling/Drilling Plan? unicorn13 Europe Club House 10 02-16-2007 04:47 AM
Advice required for my next milling machine. pigifly General Metal Working Machines 2 12-27-2004 04:58 PM
Milling/Drilling machine Ken_Shea General Metal Working Machines 0 12-02-2004 12:22 AM
