VM17 removing the enclosure
Results 1 to 2 of 2
Thread: VM17 removing the enclosure
    Aug 2012
    Default VM17 removing the enclosure
    I need to remove the enclosure to get it into the shop. It has a 45" table so it will have to be taken in pieces. It looks like lots of pop rivets will need to be drilled out. Or am I missing something. There is a lot of crud on the machine right now so a bit hard to tell but it looks like a few bolts at the edges and lots of rivets between sections. Did I miss somewhere that is made to come apart more easily? Not a bit deal if not as the rivets are easily replaced.
    Mar 2017
    Default Re: VM17 removing the enclosure
    Quote Originally Posted by Jim27 View Post
    Rivets are all I have seen, with bolts around the base, and up the column.
    Sent from my SM-G935V using Tapatalk
