VM17 spindle vfd alignment issues
Results 1 to 7 of 7
Thread: VM17 spindle vfd alignment issues
    May 2010
    us
    Default VM17 spindle vfd alignment issues
    Bad vfd. Need new HItachi drive. Spindle alignment parts.
    Attached Thumbnails Attached Thumbnails VM17 spindle vfd         alignment issues-spindle-alignment-jpg
    Mar 2017
    Default Re: VM17 spindle vfd alignment issues
    Quote Originally Posted by plane captain View Post
    The bearing is 608-2rsc3
    Clevis is d-166-1. You will have to drill it out for the pin
    Cylinder is 091-dx
    Sent from my SM-G935V using Tapatalk
    May 2010
    us
    Thanks brother. Any chance your good with Hitachi vfd parameters?
    Mar 2017
    Nope mine isn't Hitachi. Sry
    Mar 2017
    Quote Originally Posted by bmoore View Post
    Omron
    May 2010
    us
    Thanks. I sent the bat signal out to Sportybob.
  7. #7
    Jul 2010
    Hi All, talking to Plane Cap'n He is using the SJ700 drive. These drives do not do the orient correctly, The parameters are there for the creep but it does not work correctly. This drive wants you to have the "orient" option board and would require additional spindle encoder feed back, YUK, YUK and more YUK. (14 calls to Hitachi engineering to get that figured out)
    He is going to get a new drive ( WJ200) and I will get him thru the parameters.
    My drives I provide the install, wiring and parameter documentation and all the tech support you need. Mon - Sat 7:30am to about 9 PM,
    sportybob
