Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 03-29-2007, 10:17 AM
John3 is on a distinguished road
VM16 w/Centurian 6 Z axis Problem
I am running a vm16 that dosnt like tools to be left in the spindle at program end.I try to load the first tool needed ind the program at program end to save startup time. If I start up with a tool in the spindle the Z axis goes positive agenst the limit switch. The program end is written as follows:
N9900 (program end)
M05 : spindle off
G00 X2.600 Y2.000 : Begining spot
T12 M06 : Select 3/16 end mill & its length of offset
D12 G43 H12 : set nose dia. & length of offset
M30 (end of program)
Old 03-29-2007, 08:28 PM
tsutt is on a distinguished road
What does the beginning of the program look like? Todd
Old 03-29-2007, 09:42 PM
Farmers Machine is on a distinguished road
are you programming in conversational or g code?
The Farmer
Old 03-30-2007, 01:44 PM
VM16 Z Axis
I have the VM/16 back up and running but still wonder why it was having a fit.
The program was blocked stepped up to the point of the problem but it makes no sense. The program reads as follows: N2000
G00 X2.600Y2.00
T12 M06
D12 G43 H12
M08
S2200 M03
The failure was at G00 X2.600Y2.00 .When this line was moved down past the tool change the problem went away. also if the tool change was removed from the last program block there was no problem. Why would an X,Y or tool change affect the Z axis ? Thanks for the help
Old 04-01-2007, 12:56 AM
single phase's Avatar
single phase is on a distinguished road
It sounds like a flag is set when the "H" command is executed. Then when the next G00/G01/G02/G03 command is executed and the flag is set, the previous offset is completely incorporated. End the program before a move command is executed and the flag is cleared. This leaves the controller in a strange state.
At least you found a work around.
tree 220 with centurian v controller tractorguy Tree 0 12-07-2006 04:00 PM
Problem with Z axis MagTDK DIY-CNC Router Table Machines 56 10-31-2006 09:12 PM
Problem with 4th Axis Plotting TURNER NCPlot G-Code editor / backplotter 5 10-19-2006 07:35 AM
z axis problem UMASSREHAB TurboCNC 1 09-29-2006 06:45 PM
Z-axis problem Trainhound Machine Problems, Solutions , Wireless DNC, serial port 3 12-14-2005 03:24 PM
