Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 03-29-2007, 09:18 AM
Jeff S is on a distinguished road
Cent.4 wont read I or J help
Anyone have any ideas, my centurion 4 control will not read I's or J's when program is posted via the DNC. Reads I's and J's fine if programmed on machine control.
Any help would be greatly appreciated.
Jeff
Old 03-30-2007, 12:21 AM
Ben Colby is on a distinguished road
What software are you using? and what are your comm settings?
Are you drip feeding or just sending the program into the Centurion's
memory? Can you download from the Centurion's memory into the PC
correctly?
Old 03-30-2007, 06:57 AM
I'm using Mastercam version 7, program looks good. I'm sending the data via the DNC. I have not tried to download memory from machine to the PC.
Old 03-30-2007, 10:48 AM
Dave1's Avatar
Dave1 is on a distinguished road
Jeff,
There is something missing in your file. What I would do is write a small program that works at the mill, then write the same program in mastercam and compare them. Seems to me I had a problem similar to what your having and it was just something stupid with the post, could be it's omitting the circular command (G02/G03) in one or more lines. or it's calling the wrong work plane or it's not calling the plane at all.
Dave
Schneider Machine
A force of one
Old 03-30-2007, 02:35 PM
Jeff,
I agree with Dave1, write a small program like he says an try it out. One thing
I have noticed on Centurion IV's is it doesn't take much to foul up their programming. For example, a feedrate command at the end of a line instead
of the beginning can screw up a linear or arc move. If you are using line numbers? that can be an issue if they are used incorrectly. If you are programming in the XY plane, G17 is always part of my first line of programming, even though this is the default plane.
I would above everything else, make sure my communications were uploading
and downloading programs correctly into machine and pc memory before ever
attempting DNC.
goodluck
Ben
need help on milltronics cent 1 install index rotary table plast744 Milltronics 8 11-15-2007 12:16 PM
cent 6 I/O HANSENTECH Milltronics 4 12-03-2006 05:27 PM
Cent 7 Program an elipse?? out**cold Milltronics 1 10-25-2006 09:33 AM
Seventeen cent grab bag MrWild Stepper Motors and Drives 1 03-21-2006 11:34 PM
Need help installing windows 95 - cdrom wont read Hack Computers and Networking 6 02-14-2005 11:03 PM
