| Milltronics Discuss Milltronics Machines |
#15
| Cheers Dave |
#19
| I use a Centurion 6 control. I always set my tools with a setting light that you can buy anywhere for under $100. I set the setter on the back stationary jaw block on my kurt vise. I set all my tools off of that setter. Then I measure from the top of the setter to the top of my part and go to F7 Parameters, F2 Coordinate, scroll down to G54 and press the edit key. Scroll down to the Z coordinate and enter that measurement in the Z offset and make sure to press enter. Watch your signs, + or -. Then I call the offset after the tool change and tool height command T1M6 S3000 M3 G43 H1 M8 G54 G0 X0 Y0 Z.1 Works every time for me. Ken |
#21
| You must make sure that in the g54 coordinate edit screen Z is zero before you set all your tool offsets. Set all your tool offsets (H's) first then change the G54 Z coordinate. If you run a program then decide to add another tool, change your G54 Z back to zero then the set the new tool offset (H), then change your G54 Z. I always use a 2" tool offset guage so my G54 Z is always zero when setting tools and -2.0 when cutting. |
| Hass VF-1 work coordinate problems | 1strokedrs | Haas Mills | 58 | 05-10-2012 11:43 PM |
| Centurion 5 vs. Centurion 6 and validation codes | Turbo VW | Milltronics | 2 | 02-11-2007 02:35 PM |
| Work Co-ordinate Systems? Keeps spitting out code in g56... | peter.blais | Mastercam | 7 | 07-09-2006 12:51 PM |
| Macro Work Coordinate | firedog | G-Code Programing | 7 | 06-17-2005 12:03 PM |
| Work coordinate in canned cycle line | acseatsri | G-Code Programing | 1 | 02-14-2005 09:11 PM |
