Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 02-08-2007, 10:57 PM
TZ250 is on a distinguished road
Seiki 4VS Quill Handle
Hello everyone,
Where can I find a quill handle (ratchet style or multi arm) for a Seiki 4VS? The O.D. is 1.020" or 25.9MM.
I can only find 0.985" and 1" diameters.
BTW, the mill is a Centurion VI.
Thanks in advance.
Old 02-10-2007, 04:32 PM
AMCjeepCJ's Avatar
AMCjeepCJ is on a distinguished road
Not to be stupid but could you possibly modify a 1 incher if all else fails??
Just curious~
Gimpy aka 313 (three thirteen)
The early bird may get the worm, but the second mouse gets the cheese.
Old 02-10-2007, 04:47 PM
Yes, I could modify a 1" model. First, I'd have to do some other measuring to see if the pin diameters and bolt (pin) hole circle diameter are the same.
Surely, someone has these in stock.
Old 02-10-2007, 04:58 PM
AMCjeepCJ's Avatar
I guess I do not know what kind of support equipment you have, we regularly buy something close and modify it, the time spent searching is quite often more than the time spent modifying...
Newbe: how do I handle I/O jaredp DIY-CNC Router Table Machines 3 02-05-2007 06:39 PM
How's It Handle Steel? Willyb Tormach PCNC 4 12-05-2006 05:32 PM
How much weight do you think it can handle? protrxrptr17 General Metalwork Discussion 7 12-01-2006 03:54 AM
Knife Handle wjbzone WoodWorking 0 08-17-2005 12:10 PM
Will gecko's handle these servo's helidriver DIY-CNC Router Table Machines 1 11-19-2003 11:29 PM
