- VM-17 Tool change (Broken washers)
I'm having trouble getting a tool into the spindle. I'm pressing tool reset button on the front panel and the draw bar actuates, however the detente balls will not disengage enough to allow the retention knob through. The previous owner did not use the tool changer. I wonder if it needs to be disassembled and cleaned. Thanks ,Chris.
Re: VM-17 Tool change
Thank you ZZZZ , will do today.
I removed the draw bar and found broken spring washers. Does this assembly look stock? Should I replace them all?
Re: VM-17 Tool change (Broken washers)
it looks like a typical drawbar of its age to me.
Other than the belleville washers, the parts should be re-usable.
Contact SportyBob for a replacement set of washers.
Follow the instructions on the info sheet for re-assembly.
I have a nice kit that has the 90 washers and 4 ball lock balls.
PM me.
Sportybob
sportybob, I have a similar problem and want to rebuild the drawbar. How much for the washer kit and lock balls? dfportland 609-859-3000 ask for Dave. Can we do PayPal?
Hi Dave, PM me with your Contact info, and shipping address
PayPal is fine.
sporty bob
Hey Bob, I tried to PM you but your box is full. I wanted to ask the price of the washer and lock ball kit. Thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
