Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
  #13   Ban this user!
Old 06-20-2007, 01:49 PM
captainasty is on a distinguished road
Smile
What system are you running? If XP, then you need to restart the system and it should find it. If not then reinstall the software. I have a 4 extra serial to USB hub and the hypertermial shows up to 7 ports, which is correct for my system.
  #14   Ban this user!
Old 06-20-2007, 05:23 PM
Captain Midnigh is on a distinguished road
Win 95.
  #15   Ban this user!
Old 06-21-2007, 05:38 AM
Smile
Check the card dip switch settings. There should be some very small switches that will allow you to change the com ports around. This is all on the card itself. Also check your bios settings, you might have to change them also.
  #16   Ban this user!
Old 07-04-2007, 06:27 PM
No dip switches. I have tried changing parameters to: com 1, com 2, com 3, com 4, com 5, com 6. Plugging into com 5 and com 6 on the card. Connecting 2 to 3, and 3 to 2. Conecting 2 to 2, and 3 to 3 on the plug. Nothing
  #17   Ban this user!
Old 07-06-2007, 12:28 PM
bborb is on a distinguished road
Did the card come with a floppy disk or CD?
Old 07-06-2007, 12:49 PM
Al_The_Man's Avatar
To save alot of time if you are trying to confirm a port working, make up a dummy loop back plug for the port.
If 25pin jumper 2-3 4-5 6-8-20
if 9 pin jumper 2-3 7-8 1-4-6.
Anything you send out will appear on your screen, if the port is active.
I agree that Terminal is far better than Hyperterminal and much quicker to set up.
  #19   Ban this user!
Old 07-08-2007, 01:07 PM
Yes, the card came with a mini CD. My drive won't play it.
  #20   Ban this user!
Old 07-17-2007, 09:31 PM
Win95 needs the drivers (files) that are on that CD. If you can't run the CD, you're kinda screwed. If you're internet savy, you may find the files you need at driversguide.com
  #21   Ban this user!
Old 07-18-2007, 02:01 AM
I removed the hard drive and connected it to my home computer. Loaded the files on the hard drive. I now need to put the hard drive back in the shop computer and try it again.
Thanks for the help
  #22   Ban this user!
Old 07-18-2007, 07:15 AM
Wow, that was a good idea! Let us know how you make out.
