Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Milltronics
Milltronics Discuss Milltronics Machines
Old 11-07-2006, 04:38 PM
wcopley's Avatar
wcopley is on a distinguished road
Software and control ?
We have to mills with centurion 7 controls. On the RW20 when verifying the tool path it sorta paints in the tool path while cutting the VM30XP does not it just shows the cutter following the tool path. Is there a setting to change this in the control ? Also can you change it in he offline programing software ?
Bill
Old 11-07-2006, 05:51 PM
mholden is on a distinguished road
under parameters, setup, level, type in proto3 then level 3 go to misc look for special flags and set it to 016
This can be done on the offline as well.
Old 11-07-2006, 06:32 PM
wcopley's Avatar
Smile
MHolden
Thanks. I was looking in there and did not know where to change it worked
Thanks again
Bill
